Question about Refrigerators
Kenmore 6 bottle thermoelectric wine cooler
I have a Kenmore 6 bottle thermoelectric wine cooler. It is only 6 months old and it has stopped cooling. Warranty was only good for 3 months, so I'm out of luck. I looked at the parts listing and can only figure it is the computer board or the evaporator. Can someone give me some advice or tell me how to test the PC board?
Thanks
Bob
4 Suggested Answers
SOURCE:
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
  • 909 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
  • 11800 Answers
SOURCE: I have a Vinotemp VT-12TEDS-2Z Dual Zone
This cooler uses the Peltier effect = the current passing thru a very special resistance provides the cooling. Because of that there are effectively 2 separate electrical circuits inside your cooler:
1, the mains voltage that powers the Peltier element and the cooling fan - controlled by a relay
2. the low voltage that powers the control board and the display - this is the one that failed in your case.
To fix it you will have to open the front cover , access the board and test it: if it gets power then the board itself has failed; if it doesn't then its the power source and you will have to find out why it failed - probably it was damaged when another component failed and you will have to find out which one before putting a new source in.
It's a relatively complicated job that requires a good experience - if you don't have it then call an certified repairman.
Posted on Jan 08, 2011
Good day ! I have a Koolatron WC12 cooler that stopped cooling ,the fan works !It is not even a year old ?
1-800-265-8456 phone # for parts/service
Koolatron
U.S.A.
433 0 Commerce Dr.
Bata via, NY 14020-4102 U.S.A.
It is out of warranty if more than a year old.
I can find no service manual. There is a generic video: http://www.newair.com/kb/repair-cooling-kit-wine-cooler/
Replacement parts were sold at Truck Stops. That said, coolers are not known for their longevity. Source: http://www.truck-drivers-money-saving-tips.com/thermoelectric-cooler.html
What to Do When your Wine Cooler Wont Cool
Jun 10, 2017 | Koolatron Refrigerators
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
My avanti wine chiller mod ewc 16 b serial n.0800854 stop cooling what can i do ?
I've added a link for an Avanti ewcb,
http://www.retrevo.com/support/Avanti-EWC16B-Refrigerators-manual/id/867bh235/t/2/. There you can find a complete manual on the product which will help you to locate where the problem is coming from. hope I've helped!
Oct 24, 2012 | Avanti EWC16B Thermoelectric Wine Cooler...
Nov 02, 2009 | Refrigerators
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Does not chill drinks
you wrote that the wine cooler "only cools to 12 degrees minimum" I don't understand the problem?
12 degrees is really cold, in fact its freezing.
Oct 29, 2008 | Sunpentown Platinum Trim Cabinet...
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
