Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Have you checked that the socket it is plugged into is working? Try with another item such as a kettle to prove it is OK. Is the washer new or not, please? If new contact the vendor if the supply is OK. If not new I would contact whoever you bought it from! Was it demonstrated to you before you took it home?
Thanks, John C
