Question about Canon PIXMA MP160 All-In-One InkJet Printer
Paper jam keeps showing paper jam when there is no paper in the feed rollers
    Novelist:
  • 158 Answers
One of your jam sensors may be stuck in the actuated position by a paper scrap or dust, giving a jam code to your printer. There are usually two sensors, one where the paper feeds, and one where the paper exits. Try this: hand-feed a sheet of paper through the machines paper path,IN THE DIRECTION THE PAPER NORMALLY FEEDS. This may force out whatever is actuating the sensors.
Posted on Aug 09, 2008
SOURCE: 'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Posted on Aug 20, 2008
ronenfe
  • 91 Answers
SOURCE: PAPER JAM
see my other solution, glue a bluetack plasteline on the rubbers. you will need to do that occasionally.
Posted on Mar 28, 2009
SOURCE: paper does not feed into lexmark X5470 all in one printer
Rollers could be worn out. Also could be a problem with the paper sensor. Not sure what type of sensor this printer uses. Some just use a pressure switch, others use a light sensor.
Posted on May 18, 2009
celibytes
  • 70 Answers
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Posted on Nov 03, 2009
SOURCE: HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Posted on Jul 02, 2010
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
The roller on the feed tray keeps feeding through eventhough there is no paper there and the panel keeps saying there is a jam
If it doesn't do this with paper in the tray, it's a stuck paper present sensor flag.
If the machine thinks there's paper there, it tries to feed. Since paper doesn't make it to the timing sensor, it shows a jam.
Check for a stuck flag above where the leading edge of paper would be with the cassette inserted.
Mar 04, 2011 | Xerox Office Equipment & Supplies
A sheet of paper keeps getting jammed - we remove it and try again but it keeps jamming. We have cleaned the rollers inside where the cartridge goes and it did not help
If the first sheet of paper is correctly feeded and it shows up after fusing unit and that happends every time, then probably you have damaged exit paper sensor. It have to be replaced with new one.
If the paper feeds only few santimetres then you have to replace paper feed roller
pifonski
Feb 23, 2011 | Samsung Office Equipment & Supplies
The feed rollers keep jamming and feeding in at an
phyical inspection of the rollers for a jam or a roller out of its socket would be my first look.
then inspect the plastic gears at the side of the rollers as these will crack and are hard to spot untill they break completely.
Always check your printer properties first and make sure it is set for the correct type of paper.
Unfortunately if has broken gears it will be less expensive to replace than repair.. Regards
Jun 21, 2010 | Epson Stylus Photo R300 InkJet Printer
The paper keeps jamming during feed I have changed it but it still jams, I think there is a fault with the feed section at the bottom but I cant find a manual that shows technical details for repairs so I...
Did you replace paper feeder with new one? Most paper feeder problem are rubber at paper pick up roller (bottom side) and small spring at bottom paper pick up roller. Check for "something" slip at paper feeder and lubrication at paper feeder mechanic.
Feb 02, 2010 | Epson Office Equipment & Supplies
Hp laserjet 1320 paper jams constantly. not even one page prints. what could be the problem?
could actually be the paper your using. make sure your using at the very least multipurpose paper or laser paper. check to make sure your settings for paper is also set to regular paper and not cardstock or special paper or anything else
Jul 30, 2009 | HP LaserJet 1320 Printer
Printer keeps saying paper jam..there is no paper jam
You can also try using a rubber eraser as the rollers are going. Just take a pencil and lightly rub along the length of the rollers as they are feeding. This should remove the film that clogs the rollers surface.
Dec 21, 2008 | Canon PIXMA MP170 All-In-One InkJet...
or try
Jun 24, 2008 | Office Equipment & Supplies
Printer malfunction
The samsung printer have three paper jam sensors. First (paper jam 0) after the feed rollers. Second (paper jam 1) at the left of the feed rollers and third (paper jam 2) at the fuser unit where it is hot. You can see the actuator between the two white rollers. Paper jam 2 is mainly cause by the scrappers out of position on the side of the upper heat rollers.You will have to clean it and put it back into position.
Dec 19, 2007 | Samsung ML-2150 Laser Printer
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
777 people viewed this question
old marine
old marine
