Question about Britax Baby Gear
Buckle problem In order to get sand out of the buckle, I took it apart and unfortunately, am unable to put it back together with all the parts within.... could you please recommend a service center where I can get it repaired? It's a britax boulevard. Harsha
  • harshu41 Aug 10, 2008
    I dismantled the latch mechanism.
  • nobber99 May 11, 2010
    did you dismantle the latch mechanism or did you just remove the assy from the seat??
  • 48 Answers
Contact the manufacture they should be able to help
Posted on Aug 20, 2008
6ya staff
SOURCE:
HOW DO I PUT SEAT BELT BUCKLE BACK TOGETHER
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem Mazda Protege
Oct 10, 2014 | Mazda Protege Cars & Trucks
I took the cover off for washing. Need instructions to put back on
You should be able to download the instruction for this model from this site
Instruction Manuals
You will have to remove the buckle loop holding the harness at the back of the seat and release the straps. Once you insert these through the seat cover and back into the slot on the seat back you can lock the harness by re-inserting he buckle loops.
Aug 25, 2014 | Cosco Baby Gear
Why seat belt indicator stays on while seat belt fastend
I would say the sensor in the buckle has failed.
Jul 19, 2014 | 1999 Lincoln Town Car
How to adjust buckle
Slide the buckle back and lift the one side out and move it to where it should be. Put the buckle back to whee it should be
Aug 23, 2011 | DR Scholl's Dr. Scholl Dr.Scholl Shoes
I took off the cover to wash and now I'm trying to figure out how to get straps put back on
This will help if you lay out the chest pieces and all the pieces you removed on the table first. If it helps, snap them together. Then, lay out the pieces with metal prongs that lock into the buckle that goes between your child's legs.
1st pull through the belt adjusting piece through the bottom cover ****.
2nd pull the square release buckle through the second ****, on top of the piece that tightens and releases. This is the piece that you push with your thumb to release the seatbelt.
3rd pull both side seatbelts through the respective side right and left and make sure they are flat.
4th slide on the two pieces with metal prongs on one left and one right seatbelt. Before you do this, ensure that you have put the correct piece on the correct side and that they will latch properly into the buckle. Snap them into the buckle to ensure you have it right.
5th attach the two respective chest clips on one right and one left seatbelt. Snap them together to ensure you have it right.
6th pull the top shoulder seatbelt straps through one of the top cover slits. If you have a newborn, then it will be the bottom **** at the top. If your child has grown, then it will be the top two slits. Ensure both seatbelts are pulled either through the same **** on either side.
7th after you have pulled the shoulder straps through the top slits on the cover, pull them through the slits in the plastic carseat frame. Pull them through until you see them at the rear.
8th attach on their respective sides the shoulder strap at the back of the plastic carseat. There is a big brass metal piece with "hooks" at the top. The shoulder strap has a seatbelt "loop" on one end that can be hooked on. Do this on each respective side and make sure it is secure.
Oct 26, 2009 | Graco Snugride
Washed and need to put buckles back together
Always make drawing and notes of any componentry no matter hw suimple before you take it apart.
Imagine the dimensions of the baby/child in the seat to coordinate the right lengths of buckle hasp sections to required to the buckle tongues [we can term them].
Sep 19, 2009 | Evenflo Big Kid Booster Car Seat - Napa
Winnie the pooh graco car seat how to put the arm straps back together after washing
I had the same problem, so what I did was look at the first picture from walmart.com's page with this car seat.
http://www.walmart.com/catalog/product.do?product_id=10843110
I noticed where the straps went through the restraint systems, and remebered that I took the bottom ones out last, so I'd put them in first.
Then I threaded the straps through the buckle parts that snap to the bottom buckle, up through the buckle parts that snap together, then back through the holes in the cover and seat at whatever height your infant is. After that you secure it in the back like the sticker at the side indicates :)
I hope that's clear enough!
Jun 17, 2009 | Graco Nautilus 3-in 1 Car Seat
Missing buckle that shoulder straps hook into
look in local retail stores and see if you can find one like your car seat, and tell them your situation and ask for owners manual and get repair, or order parts phone number in the manual
Apr 26, 2009 | Eddie Bauer 3-in-1 Leather 22-770
Putting the belts back together again.
NOT REALLY A SOLUTION BUT THE BUCKLE HAS NOW BROKEN SO WE WILL BE BUYING A NEW CAR SEAT NOW!
May 06, 2008 | Britax Baby Gear
Nania Nuevo 3-in 1
hi,
i just had the same problem but there seems nothing out there at all, so i had to try myself and just succeeded there.
so a little step by step guide, i hope its clear enough.
1. i found taking the whole thing apart to be the easiest way. so take it apart, you should have two long straps, two metal buckles, and two plastics things you will need at the end.
2. hang the strap with the shoulder pads around your neck, the way it would lie if around your child.
3. note two whole, one on either side of the seat, inside, near where your childs bum would be. imagine the other strap, the long one coming from there(imagine we are starting form the right here), then it goes through the right buckle.
4. next it goes through the right shoulder pad
5. now in real life it would go thorugh the back of the seat, but its easier to leave this last, in case you pull it through lopsided somewhere, so you can fix it, anyhow....
6. the long strap now goes around your neck and through the other , the left, shoulder pad,
7, then it goes through the left hand buckle
8. lastly, it WOULD go through the hole on the inside left of the seat.
before you do that thought, close the buckle and see if everything is straight
9. now pick one end of your work and pull it through one of the holes in the back of the seat, once its thorugh one hole it should go through a thinner grey strap at the back, this is for tightening the whole thing at the fornt once your child sits in the seat, once thats done pull it back out front through the other hole.
10. lastly, pull the long ends of the straps through the two inside holes either side of the seat, they should come out at the bottom, the two plastic green things are then attached to the ends. there is a right and a wrong way here, one way you can pull them in tight, the other you cant
i hope this works for you and i hope i made sense....
Antje
Mar 22, 2008 | Nania Nuevo 3-in1
Baby Gear Logo
114 people viewed this question
Top Britax Baby Gear Experts
Zarir Irani
Dorel UK
Dorel UK
doobuster
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
