LOGIK LCXW32HD1 TV TV had total failure took for repair told that the power supply was us and that parts are no longer available
  • Anonymous Oct 11, 2008
    i have had exactly the same problem
I have had 3 of these sets, all with blown '+5V Standby' circuits. The culprit was the 8-pin DIL FSD200 controller chip. When it blows it takes out the little optocoupler, the small SM bridge rectifier (PCB underside) and the 20mm fuse. The FSD200 is hard to source, but Digi-Key have plenty at £0.88 each. They also sell replacement bridges, fuses and optocouplers. If you attempt the repair I recommend that you fit sockets for the controller and optocoupler. If you fit the opto round the wrong way the +5V Standby rail will try to rise to over 10V and the set's control logic may be damaged. Good luck.
Posted on Dec 18, 2008
  • ray austin
    ray austin Jul 20, 2015
    Hi, never attempted to fix a TV, but this answer is good. What are the part numbers I would need off Digi-key, on there site and can't find the optocoupler and small bridge part numbers. Any help would be great.
I am looking for a t4 standby transformer for one of these sets.
Posted on Dec 01, 2013
Logik lcxw32hd1 power blown on standby...
Although yours is a more complicated fix, I do not know if these are ic's or components that you have checked. But the one thing that will keep these stupid tv's from starting up, are the cheap Capacitors used in almost every flat panel tv that comes from China. The other components are actually usually ok. A dry cap will give a false reference to an ic, the IC will think there is a bad reference and leave the set off to prevent further damage. A good healthy capacitor will return proper standby voltage to the ic and tell it whether all circuits are working and ready. So since electrolytic capacitors are easy to replace, you might want to check them, or even just replace them with new undried ones. Yes, flat panels use reference voltage monitoring in some IC's.
Feb 02, 2014 | Televison & Video
Have a haier plasma tv model#42hp25bat. sound but no picture. can it be repaired?
Did this occur suddenly, or was the picture gradually failing over time?
Jun 05, 2008 | Televison & Video
I have a URC-7140 and want to control my Logik LCXW32hd1 tv but cannot find my instructions with the codes in. Can you help please
Click here to download the user manual to your remote control. If you feel any difficulty in downloading the same, send your email address to me by fixya, and get back a copy of it by return mail.
Jul 01, 2012 | One For All Televison & Video
TV will not turn on
You need to look inside next.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 09, 2010 | LG 42LG50 42 in. LCD HDTV
Kv-34hs420 Standby light blinks 6 times. Power supply issues?
Replace IC6501 and IC8002 at same time, both have same number and located parallel on DZ board. Part number is as follows..
670581001 MCZ3001DB
Available in Part Store.
Jun 26, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Repair part unavailable
The servicr is correct that the MAV board is no longer available, but what is the problem with the set? That board in mostly an input board. Please describe the problem, perhaps we can fix the board.
Dan
Oct 09, 2008 | RCA 36V430T 36" TV
Tatung wont turn on
I have v30dmtt 29 inch tatung and had the same problem. I took the power supply out and took it to repair man. He told me it couldnt be fixed. I contacted the manufacturer and had a new one sent. The phone # is 915-771-7554 but you need to call 1-888-482-8864 to get a case #. It costs 70.00 for a new power supply unit.The part # I needed was 6693006610. I hope this helps.
Sep 08, 2008 | Tatung V23CLTT 22.92 in. LCD Television
POWER SUPPLY FAILURE
These power supplies are complicated to work on. There are some preprietory parts that you would not be able to genericaly puarchase from general electronic parts suppliers.
If you are very strong in knowledge about power supply design, and if you can have the service manuals, have a scope and a DVM, you should have a chance to figure out what the fault is.
Take care that switching power supplies can be dangerous to work on. They employ high current using high voltages on the drive side.
Normally, these power supplies are not designed to be servicable.
Jerry G.
May 13, 2008 | Zenith R57W46 57" Rear Projection...
Televison & Video Logo
557 people viewed this question
Top Televison & Video Experts
