Question about Samsung RS2630SH Side by Side Refrigerator
Samsung Frig I have the exact same problem as you with the noise then a few days later with the hot doors and not cooling. What was the problem for you and what did you do to fix it? Thank you in advance for your help.
I had the same problem with my 2630. Unplugged the power cord and pulled the small panel off on the rear of the unit. The fan was working. I noticed a lot of dust built up on the condensor- the cooling fins were full of it. I took my small shop vac and cleaned off all that I could on the the surface of the condensor. Thought I'd try blowing it out in case I missed any in the inner part of the condensor. Reversed the hose on the shop vac so it would blow air and turned it on. Dust blew everywhere! Just vacuuming it out wasn't enough. No more problems with the heat- that seems to have cleaned it out so that the fan can now pull air across the condensor to properly cool it down. Hope this helps.
Posted on Aug 15, 2008
    Problem Solver:
  • 5 Answers
I'm not suggesting that you do this because it could possibly burn out the fridges compressor or other components and there are possible risks of fire or shock,or bodily injury. unplug refriderator before working on it. PROCEED WITH CAUTION. so with this been said this is what I did I tested all motors in fridge- evaporator fan (good) compressor (good) ice dispensor (good) condensor fan (bad) it turned out to be a burnt out condensor fan (condensor fan) is located in the bottom right hand corner. remove metal vent cover.The motor is encased in a white plastic housing attached to the rectangular condensor coils remove the plastic housing and separate case and remove the fan and motor. First do a visual inspection then check for any obstructions or breakage of any fan blades, if non then check the fan by rotating the fan blade with one finger in a clockwise position, if blade does not turn or is hard to turn with one finger the fan is possibly burnt. test with a multimeter for resistance, if line is open the motor is burnt and shold be replace with the exact model. Sears has it in stock but it will cost you, I also checked online and found a fan motor for priced for $31.90 + s/h at REPAIRCLINIC.COM if it the same make and model as mine the model# is DA31-00103A and the part number is 1075195 please check you make and model and part #s before purchasing, you can find the model number normally on the wall inside refridge and the part # would be on the fan motor itself not the plastic motor housing. thats all the info I can give you, hope it's helpful Good luck, take care.
P.S. unplug all appliances before servicing, if you are not familliar with electronics or electricity please contact a qualified repair service. Thanks
Posted on Aug 10, 2008
I have Samsung fridge model RS267LBSH. The freezer works but why won't the frig side cool?
If the door temp is reading low then it will not cool as that is the temperature the fridge thinks it is at (regardless of the real temperature). Try setting the door temp lower and see if there is still a 14 degree difference between the 2 readings. If it does cool down further and the difference is the same then I would suspect the thermostat.
Aug 16, 2015 | Samsung Refrigerators
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
New Frig Won't Cool
Good day,
If it's brand new, it's under warranty. Have them fix it or replace it. They have no choice.
Apr 28, 2010 | Samsung RFG299AARS Stainless Steel (285 cu...
My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Relay in kenmore frig
Yes it can. a short in the windings will cause a relay to fail. let me know if you want to make sure it is a compressor
May 26, 2008 | Kenmore Refrigerators
Any thoughts?
Any noises from frig at all??? cicking humming???pull the unit out and remove back cover. Is the compressor(football)size motor in back hot to touch??Lights are on in frig right?
Feb 26, 2008 | Refrigerators
Hot refrigerator
I had the exact same problem and got sick and tired of it. I contacted the Consumer Product Safety Commision and they came out and photographed my refrigerator and asked questions about the fridge. If everyone who is having trouble would write the commission we might be able to get the fridge recalled. Even if you repaired it already, they want to know the problem and what you did about it. the web site is: www.cpsc.gov. Everyone please help out. The more people we get to respond the better. ThanksZFH3I10
Dec 28, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
274 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
