Question about Mintek DTV-263 26 in. LCD Television
TV w/ built in DVD
The remote and controls are not working except to turn the tv on and off--can't change over to DVD player and even the program guide from the satellite will not display--all of the remotes have new batteries and there is nothing in the way of the sensors MY REMOTE DOES NOT WORK AT ALL EVEN AFTER CHANGING THE BATTERIES THREE TIMES. THERE IS NO OBSTRUCTION TO THE TV. THANK YOU VIRGINIA
  • amarshall33 Aug 09, 2008
    I have checked my tv same problem with no button control. I'm not about the name but I think it was a VGA board. where can I find a new one?
Hi maybe this might work on your dtv,try load a post card the size of a dvd and hold it in then try the source button to change to tv mode.It worked on my dtv-265-d now all i need is to get a remote control.
Posted on Sep 06, 2008
I need the codes to program a magnavox tv with built in dvd player with this remote
Your universal remote should have a code search feature that allows you to search through its library to find a code or codes that will work. You might need two separate codes for the TV and the DVD player.
Jun 19, 2015 | Audiovox RCR314WR Universal Remote Control...
Avol TV remote
See this links
http://shopping.rediff.com/shop/productdisplay.jsp?Universal-Remote-Control-for-all-TV,-DVD,-VCR,-VCD,-AC,-CD-Player&prrfnbr=10203960&source=browse&frompg=Accessories
Aug 07, 2008 | Televison & Video
Living solutions Jumbo remote programming
Jumbo remotes all seem to come from the same source regardless of the "brand". I do not see a code listed for your Trutech TV so you will have to do a code search. To do a search:
1. Turn on the TV
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the button
3. Press and release the TV button. The indicator blinks once.
4. Point the remote directly toward the front of the TV
5. Press the on-off button (top right) down until the indicator stays on
6. The indicator flashes until your TV turns off.
7. Press the ENTER button to store the code.
If the TV code is correct, you should be able to control the built-in DVD using the appropriate buttons on the remote. You just have to press the DVD button to do this.
Dec 24, 2013 | Universal Remote Control Hampton Bay...
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
Im trying to program a remote the tv is a zenith
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
How to clear remote so I can program it again
Link to the manual
http://audiovox2.info/docs/rca_acc/man/D770_DOC_OM.PDF
Problem: The remote is not
performing commands properly.
• You must put the remote in the
correct mode by pressing the
corresponding component key (TV,
VCR, DVD, SAT, AUX1, AUX2) so
the remote knows which component
you want to operate.
• Make sure the component is “ready”
(e.g., DVD player has disc loaded;
VCR has tape loaded, etc.).
• You may have pressed an invalid
key for the mode the remote is in
(e.g., the RECORD key only works
in VCR Mode).
• If you are trying to turn on an RCA,
GE or PROSCAN component, press
the component key (TV, VCR, DVD,
SAT, AUX1, AUX2) instead of the
ON·OFF key.
• If you’re trying to change channels,
try pressing the OK key after
entering the channel number as this
is a requirement of certain models
and brands.
*There is a possibility that a
programmed code may only be able
to control some of your component
features (e.g., only turns a
component on and off). Follow the
steps provided for programming the
remote (See Programming sections
on pages 5–7). If the component can
be turned on and off, make sure you
press the CH+/CH- key to see if the
component responds. If not, try the
next code from the list.
Good Luck :)
PLEASE rate my solution
Dec 18, 2009 | RCA DIRECTV Satellite Remote Control
Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
I need a code # to program my Universal RCA remote for my Prima TV and my DVD player
I own a One-for-All universal remote, and my booklet says the setup code for a Prima TV ( without a built-in DVD or VCR) is one of the following numbers: 0761, 0783, 0815, 0817. I can not guarantee these numbers will work with your remote, but it is worth a try.
I assume your DVD has been attached separately, and not built into the TV. In some cases, you might not need an additional setup code. Once the TV has been turned on, you simply push the DVD button on your remote, to activate the DVD. The instructions which came with your remote and your DVD should provide you with more details. If the instructions indicate that an additional DVD setup code is required, then please respond by telling me the brand name of your DVD.
Jul 04, 2008 | Televison & Video
Mintek DTV-263 26 in. LCD Television Logo
173 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
