Question about Tricity Bendix AW1000W Front Load Washer
Tricity Bendix W/D 1000 fills and drains but drum doesn't turn
Elderly Tricity Bendix Washer Dryer 1000 fills with water and drains, but the drum isn't turning. I've checked the filter and checked around the drum for jammed socks etc but to no avail. Is there anything worth trying before I call the landlord?
    President:
  • 1,462 Answers
Check brushes in motor
Posted on Aug 09, 2008
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W front load. Water leaks onto floor (a lot). Hoses dry. Pump and drain hose OK. Running the program causes leak. Pouring water into soap dispenser drawer causes leak. Just pouring...
Ether the washer is over filling or has warn out the seals. If it has been abused (overloaded) it needs serious work. other wise the sensor may be stuck. Try 1/2 cup of vinegar with a load and see if that cleans the sensor travel area past the drum but inside the tub. This is a common problem for an old machine. Best leak is on the door and you may be able to tighten the screws but be careful it could mis aligne it so tighten a small amount and test by closeing the door. Do this at least twice before turning the screws hard.
Aug 17, 2009 | Tricity Bendix AW1400W Front Load Washer
Trinity Bendix 1000- inside smells of drains
are you using gel casules that go into the machine instead of powder if so stop using them and go to powder also put a small cap full of bleach in machine and put machine on a hot wash no clothes in.let machine rinse through
Jun 23, 2009 | Tricity Bendix WDR1040W Front Load Washer...
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Dryer
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Mar 13, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Tricity Bendix WDR1240W Condenser dryer problem
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Nov 01, 2007 | Tricity Bendix WDR1240W Front Load Washer...
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
471 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
