Acer Aspire 3680 Laptop Logo
Posted on Aug 09, 2008
ITunes problem with Acer
Tried to download and install iTunes 7 onto Acer and I get an error message that says "the version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need x86 (32-bit) or x64 (64 bit) version of the program and then contact the software developer". Why on earth isn't the Acer operating system compatible with the most popular freeware available on the planet? Any ideas?
Also, when I tried to load a printer driver, the CD drive stopped working. Any ideas here?
Anonymous
Level 1:
  • Contributor 50 Answers
  • Posted on Aug 28, 2008
Anonymous
Contributor
Level 1:
Answers
50
Questions
Helped
21496
Points
62
This is because of the incompatibility of the software with the windows.
formatting your pc would help solve your problem regarding on downloading the itunes and software for your printer.
Apple application support was not found
Apple Application Support can be downloaded at this link Apple Application Support 3 0
Apple official website
https://www.lifewire.com/how-to-fix-msvcr80-dll-not-found-or-missing-errors-2623805
and
Go to Apple.com and download a copy of iTunes, install the software, it should be okay
3answers
I have a new dell laptop with vista and cannot install itunes - it freezes and comes up with an error message.
What does the error message say? Post the exact contents here.
Just in case, check to see if your computer is 32-bit or 64-bit by going to computer properties. Make sure you got the correct version of iTunes for your computer.
Check this Apple support page for more information.
I tried to download the latest version of itunes but for someone it wouldnt download and now my old itunes doesnt work either. When I click on itunes to open it up, a message box pops up reading...
It sounds like the download removed the existing software.
I would open control panel, then click add or remove programs, then click on itunes. see if there is a repair option with the installer. sometimes there is, but if not, then uninstall it, but keep your saved files.
Then re-install it, and when it sets up, it should still accept your old saved files. That way you don't have to recopy you music, games or videos
The 'error 2" is saying that when you clicked on the icon, there was no file remaining in your system that matched what the program was that was assigned to that icon.
You can find out what the program was, and its location by right clicking on the icon, and then click on properties.
8helpful
2answers
Error 7 keeps coming up when oppening itunes
A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
  1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
  2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
  3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
Other potential fixes for this issue include:
Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
Cannot download itunes8 message problem with windows installer
You may need Windows Installer Version 3.1 or higher to install iTunes (and most other programs).
ITunes and Acer - @$#%^
It depends on what operating system your laptop is running on.
2answers
Acer incompatability with iTUNES
I think Steve is correct, it's sounds like XP 64 bit or a Vista issue.
Are you going to let us know?
Ipod nano 3rd generation not recognised by computor
Right-click on your desktop, then click the Advanced tab. Then you should see on the lower left where it says screen resolution. Set this to 1024x768. This will allow you to see the setup assistant.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
