Question about Lexmark E250d Laser Printer
Paper jam Lexmark E250d
The page jams every single time in the exact same spot--after printing about 2/3 of the way down on a sheet of paper.
  • nya-laeli Oct 02, 2008
    Thank you, but this printer has a low number of pages printed. I can't remember the exact number now, but I was able to print out a spec sheet by tapping on the OK button a zillion times really fast. That page gives all the details about the printer (serial number, all the settings, number of pages printed, etc), but it also only prints 2/3 of the page. Then the paper jams.
    I'm using 80gm paper and the rear door is fully closed.
    You mention printing to the rear door, I don't know what that means or how to do it.
    Thanks for your thoughts.
  • Anonymous Dec 18, 2008
    I have the same 2/3 print, then clicks inside and stops. jam lites comes on. Rear door is tight and clicked. Just started tonight. When do you know when the drum needs to be changed?
I hate to state the obvious and I am not patronising you, but is the rear door fully closed (did it click into place) - probably. I wonder how many pages the printer has printed? If you are lucky you might be able to print out a demo page (hold the "okay" button down - the large one with the diamond/triangle on it). If it is a high number (say over 10,000 pages) then perhaps the paper pick rollers have stopped working? Also, what paper are you using? Heavy (100gsm or above) or thin (under 75 gsm) may have feed problems.
If this doesn't work you could always try printing to the rear door - this would probably stop the jam hopefully. This would enable you to print a demo page at least so you can see its page output.
Hope this helps you out.
Posted on Oct 01, 2008
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Im getting an error mp5100, after a paper jam that was removed and the error continues even though I turned the printer off several times
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch
Oct 26, 2010 | Canon Pixma MP480 All-In-One InkJet...
Where is Jam 2 located
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Apr 26, 2010 | Brother HL 7050 Laser Printer
When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
just folowe the steps
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 21, 2010 | Epson Aculaser C1100 Printer
It has paper jam some times on the begining of trasfr belt sometimes middel of that and also it send two diffrent error messages 13.01 and 13.09?
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 20, 2010 | HP LaserJet 5550 Printer
Paper jam!!
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
Hp psc 1315 paper jam
2.
3.
4.
5.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer
2.
3.
4.
5.
6.
7.
Jun 03, 2008 | Office Equipment & Supplies
Lexmark E250d Laser Printer Logo
929 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
