Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Maytag ice2o not cooling
I replaced the HV board and programmed the code. The blinking lights and door flapping problem has been solved But the fridge is still not cooling properly with no ice or cold water. Could you please help.
Thanks,
David R
5 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: The ICE2O has gone crazy
Billy, your HV control board has failed. (I know this because I serviced one just last week for the same symptoms and promptly diagnosed and repaired it.) The board can be accessed from the back of the fridge. Roll it out from the wall and look about 2 feet up from the floor on the left hand side. You'll see the cover held in place by 4 1/4" screws. Remove 3 and loosen the last one, rotate the panel out of your way. The board is a snap to remove and replace. The part number you will need is #12920710 and is available at your local appliance parts retailer. It lists for ~$150.00. The kit DOES come with instructions to program it once the repair is complete. Read these completely BEFORE doing the repair so you'll know what to do when you've got it back online.
Posted on Aug 13, 2007
SOURCE: Water & Ice do not dispense. Maytag ICE2o
Possibly the water valve (also known as a solenoid valve) on the back of of your refeer has gone ka-put. It is easy to find and spot. The water line from your source (out of the wall) goes to this valve. If it is not operating, you will get no water supply thru that line into your dispenser or your ice-maker unit. No water in means no water and no ice out. This is a pretty simple fix you can do yourself. The part is reasonably priced. Get the model number of your refrigerator off the door and contact your local distributor for your brand. Make sure you turn your water off at the wall, or house, before you start taking that plumbing line apart. Otherwise, get yourself a surfboard and lay in a good supply of paper towels. Take your time and unplug your unit from the wall to be on the safe side...
Posted on Mar 06, 2008
SOURCE: Maytag Ice2O
I concur with calling Maytag. I'm on the phone with one of their reps now and he's overnighting a new PCB free of charge. Installation is free too.
Posted on Mar 28, 2008
sodeep
  • 3267 Answers
SOURCE: Replaced HV board on Maytag MFI2568AES fridge.
increase the thermostat settings to a more cooler temperature
Posted on Dec 28, 2010
Aug 13, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
The control lights on the refrigerator keep blinking. No function for water or ice.
Unplug the refrigerator for few minutes, say 30 minutes and then turn it ON. This would reset the control board. If the problem still persists, this is an internal failure, most probably control board.If you have electronics repair experience, could read schematics, would be able to use multimeter and could keep precautions, revert and i would be able to tell you few pointers. However, repairman is recommended as it could be quite dangerous to work on these refrigerators.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2010 | Maytag MFI2568AE Side by Side French Door...
Blinking board and flapping ice dispenser.
We called Maytag customer service and they resolved our problem and is sending us a new control board and sending out a technican to our home to install at no charge! What great service! Thank you Maytag!
Jun 11, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
Lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Oct 28, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
139 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
