Question about Orbitronics Satellite Portable DVD Player with Screen
Need new rechargeable battery LPL03463F 7.2V5400MAH
7"TFTCOLOUR TV WITH DVD PLAYER
My Portable DVD Player Battery can't hold a charge
Rechargeable batteries can only be recharged so many times. They begin to slowly lose their capacity after about the first 5 charges until ultimately it won't hold a charge anymore. It appears that this is your problem. Look for a model number on the battery & do a Google search for it if you want to try & replace it. You might also find it is cheaper to buy a whole new DVD player than it is to buy a replacement battery.
May 20, 2009 | Protron 7" PORTABLE DVD
Dvd player recharger charge status lights blink
The blinking went away as I had charged it for a very long time. However, it was noted that it would not work on the DVD. The battery needs to be replaced. That solved my problem. I still have to look for a new battery for this device: US Logic 680p DVD player with recharging capabilities due to the portability option. It works fine if plugged in, but the battery just needs to be replaced if I want to use it independent of the plug. Thanks for asking how I resolved the issue.
Nov 25, 2008 | US Logic 680P Portable DVD Player with...
Dvd player does not hold a charge ( has a new battery )
take a voltmeter and test charger or borrow a known good one from a friend if you know anyone who has one , sounds like bad charger word--- it is much better to run all rechargeable devices mostly all the way down before recharging as these batteries will do what is know as establish memory and will shorten battery life do not leave on charge except when charge is needed
Nov 18, 2008 | Polaroid FLM-3732 Television
Replacement battery for Coby TF-DVD7005 DVD Player.
need a coby rechargeable batt pac. Where can I get it and how much is it?
Oct 31, 2008 | Coby TF-DVD7005 Portable DVD Player
Mintek dvd player, model mdp-1030
Mintek MDP-1030 DVD Player Description:Mintek is one the largest suppliers of DVD players in the global marketplace today. Mintek has taken the next natural step in the evolution of the company's product line combining leading DVD technology with state-of-the-art LCD technology.PRODUCT FEATURES:
Versatile playback formats;
Anti-shock function - mobile or pedestrian;
Built-in stereo speakers;
Auto power off for saving energy;
Quick connect to TV;
Digital Coaxial Output;
AV input/output;
Brightness/Color/Display mode adjustment;
High capacity rechargeable Lithium-ion battery pack;
Full function remote control.
Product Specification: DVD Player DVD Type DVD player Media Supported Kodak Picture CD, CD Portable Yes Form Factor Portable Remote Control Remote control Additional Features Auto power off Audio Features Audio Output Stereo MP3 Support Yes Connectors Composite Video Outputs 2 x headphones ( mini-phone stereo 3.5 mm ) 1 x digital audio output (coaxial) 1 x composite video/audio input 1 x composite video/audio output Power Battery Type 1 x DVD player battery - rechargeable - lithium ion General Product Info Weight 4.6 lbs Also known as Mintek MDP-1030, Mintek Manufacturer Part No. MDP-1030 Company Info Mintek Dimension 1.6 in x 10.1 in x 6.6 in (HxWxD) Model DBMDP-1030
Aug 17, 2008 | Compaq Presario Notebook
Dvd battery
Hello sara_lou,
I have 2 suggestions for you:
1) Look into purchasing an external rechargeable battery pack for PDVD units (available at Best Buy). It is an external pack that will connect to the players AC port.
2) Prepare for surgery! You will need 6 rechargeable AA batteries, a soldering iron, super glue, and patience.
You'll need to open the battery case and look at the batteries within. Note the direction and polarity of all the batteries and how they are wired/soldered together. You will need to replace all these batteries with the new ones you have purchased. Wire together the new batteries in the exact same order and polarity as the old dead ones. Remove the old ones and replace with the new ones. Solder in where necessary and be sure not to bridge any contacts. Put the case back together with a little super glue on the seam. Replace into the PDVD player when the battery case is dry (or else you may permanently mount the battery case into the player) and set to recharge using the AC pack. if everythign was wired correctly, you should have a charged battery pack in about 1 hour (since most rechargeable batteries come with 3/4 charge in them).
While I don't recomend this second solution, it is plausable for the hobbiest electrician or DIY-er.
Best of luck to you!
Jul 20, 2008 | Insignia IS-PDVD10 Portable DVD Player
Portable dvd player
I found one for my PDV-288 at www.techexcess.net at a very good price. Now I just need to find a source for a new rechargeable battery.....
Dec 21, 2007 | Protron PDV-288 7" LCD Portable DVD Player
Portable craig dvd player--
Craig will sell replacement battery for $18 over the phone.
Dec 07, 2007 | Craig 731398407019 Portable DVD Player
Orbitronics Satellite Portable DVD Player with Screen Logo
182 people viewed this question
Top Orbitronics Televison & Video Experts
Electro Med Services...
Are you an Orbitronics Televison and Video Expert? Answer questions, earn points and help others
