My zanussi washing machine wont spin and drain
  • Anonymous Mar 07, 2009
    my zanussi washing machine wont spin or drain
My bosch washing machine also wont spin and drain
Posted on Aug 09, 2008
SOURCE:
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
Sep 05, 2016 | Zanussi Washing Machines
Wont spin.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 16, 2011 | Zanussi W1042W Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
My Zanussi zwx1605w
norm faulty heater/element iff not faulty pcb
Jul 13, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Filter can be clogged, pump can be dead or water outlet clogged.
Apr 11, 2008 | Zanussi ZWF1430W Front Load Washer
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
My Zanussi F1245W Wont Drain or Spin
Check the drainpump. It could be burned og blocked.
Jan 20, 2008 | Zanussi F1245W Front Load Washer
Washing Machines Logo
303 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
