Question about Kenmore Dryers
Lint filter for dryer
I was emptying my lint filter when one of my socks slipped into the opening? How can I fix this. My dryer shuts off and makes a wierd noise?
Lisa Mielke (410) 636-3749
  • 1,198 Answers
Sweet, the sock is probably in the fan area now, I hope it didn't break anything. Open up the back and open the sheetmetal cover for the filter area. It should go down to the motor and fan area. The sock should be there. Clean the area while you're there, it catches little things that fall out of the dryer. Of course, unplug the unit before working on it.
Posted on Aug 09, 2008
How do I remove a sock that fell through the lint trap?
How To Fix Dryer Lint Trap Problems (Removing Items That ...
? 5:32
Feb 4, 2015 - Uploaded by UKaToNeN
Have you ever had something fall down into the lint trap on your dryer? It`s happened to more folks than you ...
how do I get sock out of lint filter shoot of electric dryer ... > Manage My Life > Questions
I'm sorry to hear that a sock fell into your lint screen chute and I would like to assist you. Be sure to unplug the dryer prior to servicing it! Do not run the dryer until you are able to remove the sock! There are two ways to do this.
Nov 29, 2015 | Electrolux Dryers
Takes extra time to dry the clothes.
You may need to clean out your lint trap. Not just the part that you pull out. I'm talking about the entire tunnel. Even though we empty the lint trap regularly there's a lot that gets left behind and over time can become a fire hazard. Your arms and hands cannot reach everywhere in there. For this you can attach an old sock or rag to a coat hanger that has been opened up. Go down in there a couple of times with it. You'll be surprised at how much stuff comes out. To further help this problem you can also pull dryer out and check that the vent hose in back is clear and free of debris. Cleaning the trap screen (the part you pull out to empty the lint) with HOT water occasionally will also clear residue that has built up from using dryer sheets. Over time that residue will make those tiny screen holes smaller & smaller & smaller. All of this can affect your dryer's performance.
I hope this info was helpful to you. Good luck!
Jan 29, 2010 | Whirlpool GEW9250 Electric Dryer
Sock fell down lint vent and daughter turned on dryer
Turn off you power to the dryer and then,
You could run a coat hanger straightened out with a hook bent on the end of it into the lint vent at try to hook the sock.
But probably you will have to remove the back to follow the lint vent.
You may try to remove the vent hose and run the straightened coat hanger in there to try and remove the sock.
Hope this helps
Sep 30, 2009 | Whirlpool LEQ8000JQ Electric Dryer
I ran the dryer without the lint filter in it and now it is noisy
First of all, You have a serious safety issue. Your dryer may catch fire. DO NOT USE YOUR DRYER.
Something went into the mechanism (yes, may be another sock), and a lot of lint went inside the dryer. The dryer needs to be cleaned by a technician. Using the dryer on its condition may cause a fire. Don't get your house burned down just to save some money doing it by yourself.
Aug 30, 2009 | LG DLE5977 Electric Dryer
Sock in lint collector slot
Take a hanger Metal one, stick it down there and twist tell you get a good grab on the sock and pull it out. The other way is to open the back up and get in there. The machine will not work at all cause it can not exhaust
Feb 09, 2009 | Kenmore 62622 Electric Dryer
Dryer wont start
you can try removing the lower acess panel(3 screws across the front bottom) then a few more 1/4 screws will release the lint filter housing giviing you acess to the blower fan assy, chances are ther eis a sock or other debris holding the fan from free spinning and t hen locking up trhe motor.
Jan 10, 2009 | Whirlpool GEW9250 Electric Dryer
My dughter dropped an empty gum wrapper into the lint trap slot on an older whirlpool...anyway to get it out without taken aprt the whole darn thing?
the lint filter up top??? if so can oyou hear hte gum wrapper making noises???? if not i wouldnt worry about it, that bent is a direct vent thoughthe blower fan housing and strait outside! id worry if a sock or bra, something of that nature, not a gum wrapper youll be fine
Dec 03, 2008 | Dryers
I took lint filter out to clean it and forgot to put it back in, I started gas dryer and it stopped, I believe there is a sock stuck in there somewhere. Does the front come off and what do I need to take...
Hello Kims987K,
You may want to check circuit breakers in your Breaker Panel to see if the one for your Dryer is tripped, and reset it if it is. Even though you have a Gas Dryer the Drum still operates on electricity, so without it the Dryer wouldn't function at all.
I don't think that the sock is stopping your Dryer, as the lint filter just filters lint from your Dryer's exhaust. So, even with the lint filter out a sock couldn't fit through the small holes in the drum that ventilate it (that's how the lint gets to the filter). I guess there could be a switch that detects whether the filter is in the machine and cut it off though, so you may try to re seat the lint filter (replace the lint screen/filter making sure it's in all the way), and try to start it again. If you look inside the Drum and see any way that a sock or anything else could get out other than through the door opening? That would be a problem.
If the filter was missing for several loads of laundry? Then you could have a restriction in the exhaust causing a thermal overload circuit to cut it off too (prevents the Dryer from catching fire). Does the light come on in the Dryer when you open the door?
From the information you posted, all I got is that it's a Gas Dryer that won't run and you appear to be missing a sock, so more detailed information will probably help in finding your solution.
I'll check back, and Good Luck finding that sock.
Mar 05, 2008 | Dryers
Dryers Logo
124 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
