Question about E-Machines Computers & Internet
Need to reload system - E-Machines Computers & Internet
  • twombolt Aug 09, 2008
    need a back up disc to reload intire system back to original
  • Igor Ceke May 11, 2010
    Are you trying to reinstall windows xp?
    Novelist:
    Scholar:
  • 125 Answers
You will need to download the drivers for all your hardware devices first from the Computers site, like for instance DELL, ACER and so on. You will need to search for the download drivers section or support drivers and also you will need the model number of computer to download correct drivers.
To install windows fresh onto system you will require either the Recovery/Restore CD or Windows XP/Vista. You will also need to set your bios system to boot the cd rom first so that it loads the installation as you start-up computer. If you have any problems repost questions or queries. Good Luck!
Posted on Aug 10, 2008
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
App error 205
Unfortunately you are going to have to reload the OS. You can find the instructions on how to reload the OS from :-
http://crackberry.com/blackberry-101-lecture-12-how-reload-operating-system-nuked-blackberry
You'll also need to download a new version of your OS, which can be found from :-
http://us.blackberry.com/support/downloads/download_sites.jsp
An app 205 error is a nasty error which is embedded in the software and has no work-around fix. Unless you fix this by reloading the OS, you'll basically need a whole new phone. Fortunately, reloading the OS has a very high success rate so I'm sure you'll get yours up and running in no time!!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Need to reload my drivers
Hello
To reload your drivers you will have to reload the entire operating system and here is how to do so.
Back up all of your user files, because reloading the operating system will destroy all of your data. You can use an external hard drive, thumb drive or an online backup service to save your files.
Insert the restore CD that came with your computer, then restart your PC. The computer will automatically boot and begin the restoration. You will be asked to confirm the reformatting of your hard drive during the process. The restore CD will not only reload the operating system but all of the hardware drivers as well. (If you do not have the restore CD, contact your computer's manufacturer.)
Insert the operating system CD if you do not have access to a restore CD. Shut down the computer and restart it. The computer will boot from the CD, and when the operating system menu is displayed, you will have the option to reload the operating system files. If you take this approach, you might also need to reload the drivers for your hardware by going to each manufacturer's website and downloading a driver for each device.
Jul 04, 2010 | Velocity Micro NoteMagix x25 PC Notebook
Phone will not turn on screen says device error 377
you will likely need to wipe your device using JL_CMDER and then reload your operating system
also try this link
Apr 07, 2010 | RIM BlackBerry 7290
I would like to format my computer and reload windows vista on it again. can you tell me how to make a vista disc so i can reload it
You will need to contact your manufacturer for a reload disk that that you can reload your operating system. If your computer was recently purchased or is under warranty, many times they will not charge you for the disk, only shipping and handling. If that is not an option, then you can go to your local Best Buy or other computer store and purchase a reload disk or purchase the operating system.
Nov 22, 2009 | Acer Aspire 5315 Notebook
Toshiba - Satellite A75-S1253 STOP: c000021a {Fatal System Error} The Windows Logon Process system process terminated unexpectedly with a status of 0xc0000034 (0x00000000 0x0000000) The system has been...
you have to reload the operating system.get our xp or what ever os your running and boot off the cd.if you have any questions or need help with reloading the os,and data recovery please email me at gamecrazy944@yahoo.com
Jul 16, 2009 | Computers & Internet
Reloaded xp by mistake
you can not undo a reinstall, you'll need to load the drivers from the oem cd or download them from the oem web site
Jun 09, 2009 | Microsoft Windows XP Media Center Edition...
Dll error
This is an operating system error. You will need to run a system repair or reload with your recovery or operating system disc. Start with a repair, if the repair doesn't fix it, then reformat and reinstall the operating system. If you have any issues or problems during the format or reload, then your hard drive has failed and will need to be replaced.
Jul 20, 2008 | Toshiba Satellite A75-S231 Notebook
Blue screen
The blue screen indicates either an operating system error that will need either a system repair or reload using the system recovery disc or an operating system disc, or it indicates a hard drive failure, in which you will need a new hard drive. Start by trying a system repair, then reload if the repair doesn't work. If the machine has issues during or after the repair/reload, then it's the hard drive. The blue screen should have an error code. Sometimes it's helpful if you list the error code, it could tell us exactly which it is. I won't be back until tomorrow, but if you want to try the repair/reload tonight, and if it doesn't work let me know and I'll see if I can tell you what the code means.
Jun 22, 2008 | Dell Inspiron 6000 Notebook
Mce gives a decoder error after reloading system
Problem resolved
after loading the system , place Recovery disk 1 which exhibits all the applications need to be recovered.
Thanks
essar
Mar 04, 2008 | Sony VAIO VGC-RB42G PC Desktop
Computers & Internet Logo
32 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
