Question about HP Photosmart 3310 Printer
Scan head disconnected
Scanner was jamming, opened it up and now the scan head is disconnected from the belt. How to reattach please ?
    Genius:
  • 1,847 Answers
Chk this link it will help you....
http://fatrcat.com/hp7100/scanner.html
Posted on Aug 09, 2008
  • Legin Varghese
    Legin Varghese Aug 09, 2008
    if think the solution was helpful please rate fixya.
Unable to init see troubleshooting and routine maintenance chapter in user's guide. Please help me!!!
1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.
Disconnect the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2. If the error continues to appear, move the print head and examine under the print head.
NOTE : The images shown below are from the representative product and may differ from your Brother machine.
2-1.Disconnect the Brother machine from the poweroutlet.
2-2.Open the scanner cover by pulling up on the lower right corner of the cover.
2-3.Check the print head's position.
In the example photo the print head is positioned at the left hand side of the platen area.
2-4.Gently move the print head to the center.
Examine under the print head. If anything is found, remove it.
Close the cover and reconnect the machine to the power outlet.
Feb 20, 2014 | Brother DCP 115C All-In-One InkJet Printer
Belt is loosing
you can open it up and have a look at it to see if it is the belt sometime it can be another problem
Jun 03, 2012 | HP Scanjet G2410 Flatbed Scanner
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
HP 8270 does not scan on windows Vista . Could not complete scan is the error message
Make sure you have the newest vista drivers located here - also, make sure that the scanner platen is travelling the full length of the scanner, it's not being hung up somewhere causing it to jam. Try to scan while the cover is open to watch the scanner head travel.
Oct 21, 2009 | HP ScanJet 8270 Flatbed Scanner
Paper jam
For this and any other print jam problems try this;
Open the scan bed tray and push down the button at the front (scan bed tray open switch)
I found if your print jam occurs and you go through this procedure, the jam clears itself.
With the tray still up and switch held down, try and print something.
See how far the paper goes through the print cycle before jamming. If it jams when it reaches the print head...clean under the print head and try again.
Hope this helps
Mar 17, 2009 | Brother Multi-Function Center MFC-665CW...
E9 code
E9 code means there is a paper jam.
Clearing Paper Jams
If your scanner stops scanning due to a paper jam in the Automatic
Document Feeder, a warning dialog box opens after a few
moments.
To clear a paper jam:
1. Press the ADF cover release on the top-left of the scanner
body to open the Automatic Document Feeder cover.
2. Remove the jammed paper and close the cover.
To reduce the number of paper jams, smooth and straighten the
paper before scanning and adjust the guides to the paper size.
This should help. Please let me know if it does. Thank you, Binary Bob
Dec 04, 2008 | Xerox DocuMate 252 Path-Through Scanner
37,004,40:45998 fault code the printer is dead any suggestions? also someone locked the scan head with the transport lock on the side of the scanner then ran the machine. This jammed the scan head of...
There are very very few parts spared for that feeder.
You can try looking up The Parts Drop on google, but I don't know if they carry any parts for that scanner.
Nov 12, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Initialize printer
I have had this problem on numerous times over the last five years. The way i have cleared it is to remove the plastic cover covering the buttons by gently lifting with a small screwdriver. Then tug at the buttons especially the scanner button to release it as it sometimes seems to gets caught. I also turn off the machine at this point from the power source for about 10-15 mins restarting after this time this generally clears the jam. I have also on the odd occassion uninstalled the software and reinstalled it, mind you it has taken a day on one occassion to clear the jam.
Oct 07, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP Photosmart 3310 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
