The control goes in the door...it is easy to get to.
Just take the screws out of the inside panel of the door, they are around the outside edge of the interior of the door. The panel will then lift off and the control will be near the top on the inside.
Make sure the power is turned off to the dishwasher and then one by one remove the wires from the old board and place them on the new board. then remove the old board and fasten in the new one. replace the panel and then give it a trial run.
Everything should be working just fine but some of the timing will be a bit different.
heatman101
Testimonial: "Thanks so much! "
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
heatman101
Asker
heatman101
oi57
heatman101
59iwsbf
