Question about JVC TH-C30 System
Sub won't stay powered up
JVC TH-C30 will not play sound. Receiver lights up and appears to be playing radio or CD, but no sound. Noticed power indicator light on sub comes on briefly when first powered up, but then goes out within a couple of seconds. Took cover off of sub and found 3 fuses, all of which are good.
Took cover off of receiver, fuse was good there too. If I unplug the cable running from the receiver to the sub and plug it back in the power indicator light on the sub will again light back up and go back out within a couple of seconds. I hear a relay switching when the light goes on and off. I've only had this unit a couple of years and haven't used it but 3-4 times Any help would be appreciated. Lankford
  • 2 more comments
  • Lankfords Aug 09, 2008
    How would I go about determining this? I have no sound at all. Thanks
    Lankfords
    Yes, the speakers plug into the back of the sub. The sub speaker read ~4 ohms when I unplugged it from board. The other speakers are ~6 ohms. I only have a 12 volt test light I use on my vehicle. When I checked voltage with a voltmeter where the speakers plug into the sub I didn't read any voltage. nor did I read any voltage when checking the pins that the sub plugs into.
    I tried to send a couple of pictures, but I could only send pictures of a certain size. Thanks
  • Lankfords Aug 10, 2008
    thanks
  • Lankfords Aug 12, 2008
    I'm not sure I know exactly what part you said works. I assume you're talking about the rack that sits in the bottom of the sub that has circuit boards, transformers and etc.? Thanks
  • 33 Answers
Well if your getting sound out of your surround speakers then the sub is busted, if your getting no sound at all then your speaker input's are either bad or out... i would test the speaker inputs...
Posted on Aug 09, 2008
  • 2 more comments
  • Justin Griffin
    Justin Griffin Aug 09, 2008
    if im not mistaken i think your speakers plug in the back of the sub... if thats the case then you can take your sub out of the encloser and see if it moves off the cone or if the coil is burnt up... a coil is the wire that connects from the sub to the sub input where the wires go... if your speakers plug in the back of the receiver then take the casing off and get a light tester, (just a tester that looks like a screw driver but has a light and a gator clip on it,) and test each input...
    If your still having problems let me know and ill send you a pic, of what im talking bout...
  • Justin Griffin
    Justin Griffin Aug 10, 2008
    GooFyTiS24@aim.com is my email if you want to send those pics.
    i dont know if JVC has a replacement part or if you half to buy a new one... but it has a built in amp/receiver in the sub box... thats is whats bad... its not getting power to the speaker inputs, i have a spear one at my shop for the th-c50 i dont know if it will work but i will test it out on the th-c30 system and see if it works if it does ill tell you more detail on how to fix it... cause the th-c30 is a older system so jvc having spear parts is probley rare...
  • Justin Griffin
    Justin Griffin Aug 11, 2008
    well it will works but its a lil bigger then the c30, the box size is bigger then the c30. but you can also just take the sub from another series like the c40 or 50, and use it, it will run just fine on your system...
  • Justin Griffin
    Justin Griffin Aug 12, 2008
    If you got the cover off the sub, there is a bored back there that has speaker inputs on them, that is the piece im talking about... its what powers the speakers... that part is bad, it could be from 1 of 3 things, either a fuse on there is out, a wire off one of the coils is burnt out or the chip it self has gone out...
    i dont know if you have pic's of your system and of the inside of your sub mainly the bored area but if you do that would help me out alot, cause i could see just what is wrong with it...
Can't get any sound from the satellite tv to play through the surroundsound system
Connect video and aux in and choose vcr from inputs in jvc.
Apr 19, 2014 | JVC TH-C30 System
Sub would only sound when am listening to radio would not sound when playing dud aux but surround speakers play
Possible that the connection to the AUX does not activate if you are using RCA inputs. Connect the DVD using the optical cable or the coaxial link and it must play better with surround and subwoofer in DTS.
Oct 26, 2011 | JVC TH-M303 System
I have a jvc seteup but reciever is broke.is there a way i can get a adapter to plug sub woofer with power amp into a a yamaha reciever?the plug that goes from sub woofer also powers other speakers, cable...
Here's a manual.
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
That cable not only carries audio but it also powers the sub and other channel amplifers. Even if we could supply the pin-outs for the channels I'm not sure what we could do to provide subwoofer power. We're talking about a major rework.
This is a highly proprietary design, meaning it's really not very adaptable to normal spec audio equipment.
There's a flat-fee repair service for the receiver ($99.95, free return shipping):
http://cgi.ebay.com/JVC-TH-C50-TH-C5-TH-M505-Repair-Service-/360178567658?pt=LH_DefaultDomain_0&hash=item53dc50c9ea
Maybe they could fix your receiver.
You COULD try to reach the manufacturer for other options.
http://www.jvc.com
800-252-5722
Jan 12, 2011 | JVC TH-M505 System
No power. Will not come on with remote or manually. Switched power cords with no luck. Green light on subwoofer off as well.
On the bottom board is an electrolytic capacitor (C975) that might have failed. The top will be convex (bulged out). Since this is in the power supply, the unit will not work. Also: Check resistor R4843 and diode D4709 for charring on the board (indicates extreme heat). I have been trying to find the value of that resistor and so far no luck. Replacing the cap brought the set to life, but there is still a problem since the sound will cut off momentarily randomly. The receiver unit is at fault, not the sub unit. So I could use some help as well!! Good luck.
Dec 31, 2010 | JVC TH-C30 System
JVC TH-C30 dvd movies skip
Check your formatting on the DVD recorder, you need to finalize the disk to be playable on "any" player. That should solve the issue. Your JVC is looking for specific code as it reads the disc, when it's missing or not understood by your JVC it will either stop play or skip over it's interperated missing info. Hope this helps
Jun 23, 2009 | JVC TH-C30 System
Jvc th-c30
sharazanct I had the same problem and posted here many months ago without any success. Just today, believe it or not, I decided i would replace the screws in the top cover and try it one last time. I don't know why, but it now works fine.???? My original problem was my receiver would light up and appeared to be working but I would get no sound out of the sub or speakers. I noticed at the time when I would first turn the receiver on the green indicator light on the front of the sub would light for a couple of seconds and then go out and would get no sound. Today the sub light lit and stayed on and I'm therefore able to hear sound as if everything was normal. I wish I knew exactly what I did, unfortunately I don't. If you have everything back together you might try unplugging the receiver and sub for some amount of time and come back and try it again. Good Luck!
May 04, 2009 | JVC TH-C30 System
I have a JVC TH-M505 home theater system and when I plug everything together and turn the power on the main unit and begin to play a cd/dvd etc...I cannot get the sub unit to power up (the light does not...
you may want to re check all your connections.
are you plgged into a power bar or directly into a wall socket.
also you may have a defective power supply on the system . you can also check this website out it is free to join and you can download manuals and get help
http://audio.manualsonline.com/manuals/mfg/jvc/jvc_th_thm505.html
Apr 26, 2009 | JVC TH-M505 System
Problem with my JVC KDS51
you somehow crossed a wire with the brake light
Aug 13, 2007 | JVC Car Dual SIRIUS Satellite Radio/CD...
JVC TH-C30 System Logo
268 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
