Question about Sony Playstation 3 (PS3) Console
Hdmi problems the hdmi cable broke off in the console i can't get the pieces out and the system will not even play on the regular cables its my sons machine and hes away at camp would like to have it fixed before he returns. thanks buck69
  • 33 Answers
Just pull the casing off and get the hdmi slot and get you a small small flat head and wiggle it out... it should come out with no problem cause you can push it from the back of the hdmi slot...
Posted on Aug 09, 2008
I played my xbox 360 on a hd tv, then i switched to a regular tv and the picture wont work. What should i do?
If you are using the video cable (multi-colored jacks on one end, big trapezoid on the other) with the switch on it, make sure the switch is on tv and not hdmi. If you are using the hdmi cable (small trapezoid connection on both ends) then you need to find the video cable. You should also check and make sure that your screen settings are not for HD.
Go to:
System settings
---Console Settings
-------Display
----------HDTV settings
If the HDTV settings option is available then you have the hdmi cable attached or the switch is flipped on the video cable causing the 360 to think you're transmitting to an HDTV.
Hope this helps you.
Dec 17, 2010 | Microsoft Xbox 360 Console
What do I change to switch from HDMI cable to the RCA cables?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try a video reset. With the A/V cable connected.
1:Turn the system to off/standby, where only the red light is on.
2:Then hold your finger on the front power button, it will turn on beep twice then shut back off, release finger.
3:Then turn back on normally.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
No sound from hdmi cable
Go to the Sound settings in PS3 and be sure it's listed as HDMI and not Audio Video Cables.
Output on TV may be set to surround sound system? Powerd On?
May 25, 2009 | Sony Playstation 3 (PS3) Console
I cant get my ps3 to play threw my sony surrond system period the tv is a sony too i have all the hdmi cables hooked up why wont ps3 play on the surround?
You can't get audio from HDMI cables. You have to connect the regular AV cables into your sound system first or you can use the digital output from the PS3 into your sound system if you've got the right cables. You'll also have to configure this through the audio settings. This should solve your problem. Let me know if it doesn't.
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
HDMI Connection
Yes it does, HDMI can handle more information and provide better picture and sound. Works like this, Cable-OK, Component-Even Better, HDMI and DVI-both Digital and the best sound and video. The only way to get full HD is with HDMI or DVI. Hope this helps
Jan 17, 2009 | Philips 52 In. LCD HDTV
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
This happened to me a few years back so I apologize if it's not 100% accurate. If you can get it to work on another TV, go ahead and connect it to that, and go in to the settings to select the video input. If it's connected through an HDMI cable, then it will probably be set to HDMI. Change the input here to whatever cable you used in the living room. You will have to power it off at this stage, but when you connect to the other TV it should work.
Mar 14, 2017 | Sony Playstation 3 (PS3) Console
Have purched a hdmi cable for my playstation 3 but have no sound
ensure the regular composite cables are hooked up to determine whether audio is bad. (the yellow red white cable) ...unhook your HDMI cable for now....
Nov 11, 2008 | Sony Playstation 3 (PS3) Console
Ps3 hdmi-av
i currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
Hope it helps =)
Nov 17, 2007 | Sony Playstation 3 (PS3) Console
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
