Question about Acer Computers & Internet
How to change ram - Acer Computers & Internet
    Novelist:
    Scholar:
  • 125 Answers
You will need to open the box of your computer,assuming it is a desktop. The ram or memory is usually located near the power supply below it. They are small boards slot into a slot and has two pegs either side to hold it in place. Before you go out and by new ram you will need to make sure it is compatible to your motherboard. The best way to do this is to take a stick along with you so you can purchase the correct type. Once you know the correct type, you will need to know whether it will run on your system and how much memory your motherboard will run on. Most retailers or computer tech should be able to let you know as long as you know what type of computer you have. If it is a brand name it's easier. Like for instance Acer, Dell or Samsung and also if it's a pentium 3 or 4.
Posted on Aug 09, 2008
    Scholar:
  • 53 Answers
Hi
I am not sure if you want to change the RAM in Desktop computer or in Laptop.
Anyhow, if it is Desktop computer, then go through the video given in the below URL:
http://in.youtube.com/watch?v=QLf_ns-GNDg&feature=related
It will show how to replace the RAM.
If it is laptop, then there will be service manuals avaialbel from your Laptop manufaturer on how to replace them
Esonic mother board ram problem. i was changed ram but still beeping. psu changed but still beeping. what i should?
Make sure that you are inserting the correct type of ram - many mo bo's are very sensitive to what you throw in there and will not work with just any ram. Put in the exact stuff called for by the manufacturer.
And are you sure it is a ram problem? There are beeps for other hassles other than ram. Check that out.
Aug 19, 2015 | Computers & Internet
Toshiba T2300 one beep. what does it signify ?
Hi Friends,
If one sort beep then you pc safe not any problem. Because RAM active mode coming show. But if one long beep then RAM damage and change ram, but some conduction occurs like dust, loose connect etc. So you check it first RAM slots. if possible change RAM Slots (connect another port).
Thanks..
Sep 19, 2013 | Computers & Internet
My computer on booting stops and restarts on his on and giving a stange sound. something like this
If you changed the ram and still have the problem, is the ram socket.
In this case you can change main board.
Aug 05, 2012 | HP Compaq d530 SFF PC Desktop
.i want to change my
make sure ram module its securely seated also this ram might not be compatable with your computer try to keep the same type of ram you already have is it ddr2 or ddr3, sdim,sim 30 pin,sim 72pin ,or dimm
hope this helps
Sep 02, 2011 | Intel D845GLLY Motherboard
CANNOT INSTALL WINDOWS XP AS IT SHUT DOWNS WHILE LOADING SETUP FILES AND SHOWS A BLUE SCREEN.
Hi deepakbandi2,
This could be as a result of a bad RAM chip or bad hard disk , due to bad sectors in it,
Please follow the below steps :-
  1. Make sure that you connect your RAM properly in the slot , if required remove the ram , clean it and change the slot where the RAM is fixed , for instance , if you had RAM fitted in slot one , change it to slot 2 , sometimes this could work fine.
  2. Try to do a full format of the partition that you select so that the files are copied properly, if this does not work try to install the operating systems on a different partition than you usually use, for e.g. if you were used to install the OS in drive c , try installing it on drive D , and make sure you have C and D drive formatted properly.
  3. If the above methods don't work , then try changing the RAM with one of your friends and check if everything works fine after RAM change , if it does , your probably need to buy a new RAM.
Hope this helps...:)
May 11, 2011 | Computers & Internet
Hardware malfunction call your hardware vendor for support NMI : Parity check / memory parity error the system has halted
Try the RAM modules one at a time in each slot. If issue is isolated to 1 module, replace the RAM module. If isolated to 1 slot, replace the Motherboard. If RAM changes make no difference, change motherboard
Oct 06, 2009 | Computers & Internet
Beeping on start up
Your motherboard has 64Mb built-in RAM and the video card needs some video RAM and has grabbed 8Mb of RAM which leaves the system with 56Mb of RAM. When you insert a 64Mb RAM module you have a total of 128Mb of which the video has grabbed 8Mb which leaves the system with 120Mb.
You can't change stop the video card from grabbing 8Mb of RAM, the RAM is essential for the video to work.
You can upgrade the RAM by removing the 64Mb RAM module and insert a 128Mb or 256Mb RAM module. You may even be able to insert a 512Mb RAM module if the motherboard will accept it, you need to check the specification of your laptop to see the maximum amount of RAM the laptop can handle.
May 21, 2009 | Compaq Evo Notebook N150 Notebook
I put in a 512MB PC-133 memory stick and all my pc does is beep 3 times when I turn it on
1). Changed ram is of high frequency so its not supporting ur motherboard, change the ram and see to its frequency (eg. pc100, pc133)
2). Or you might have wrongly attached the ram to motherboard, so ram slot might have burnt.
May 04, 2009 | Dell Dimension 2300 PC Desktop
Monitor won't come on after changing ram.
Make sure that the new RAM is fully seated into the slot. The snap clips on the side will automatically lock in when the ram is fully inserted.
May 26, 2008 | Computers & Internet
No display
Dear hubult,
There is issue with u RAM because when u remove the RAM it starterd beep it means u r RAM slot is ok. the problem is with u RAM pls change the RAM and then check it and one more thing before u change the RAM do one thing take out the CMOS battery and then restart the system after restarting the system shut down the system and then reconect the CMOS battery and start the system.
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845BG (KD845BGPAK10)...
Computers & Internet Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
