Question about Texas Instruments TI-83 Plus Calculator
Random screen My son gave me his TI83 after not using it for over a year. We replaced the AAA batteries. It is powering up but a series of vertical lines or a blinking horizontal line appears on the top or the middle of the screen. A couple of times pressing "clear" several times corrected the problem, but generally it really is not usable. Any suggestions?
  • momojj May 08, 2009
    yeah, same here. especially when i enter a problem on the bottom line and hit enter, the whole screen fills with vertical lines. help, plz???
  • 360 Answers
I'd try reinstalling. Can you connect to the computer and use ti connective software. You can download everything from the ti web site. need more help to step you through it email me at: raklein62@yahoo.com
Posted on Aug 27, 2009
We have a Ti83 Plus Silver Edition we bought around 10 years ago for my daughter. My son is now using it and it goes through fresh AAA batteries in a matter of a day or two. It works fine otherwise, what...
If i were you since it goes through batteries so fast i would either buy some of the electronic batteries that are supposed to have super long battery lives but cost more or i would buy rechargeable batteries so that i wouldn't have to go out to the store and keep buying new batteries.
Nov 08, 2010 | Texas Instruments TI-83 Plus Calculator
When I turn it on, the calculator will not run its usual functions. It's like it freezes. I have attempted to change the batteries with no results. The screen also shows random symbols, not any thing that...
Hi
its a common problem with the TI83 Plus
there is a component on the main circuit that need to be replaced
I fix this problem all the time it will ocst $20
let me know if you want to fix the Calc
ecrdn@yahoo.com
Jack
Nov 02, 2010 | Texas Instruments TI-83 Plus Calculator
TI-82:blank screen like a dead battery. Just put in new batteries (all). Not used in years. Won't turn on -- anything I can do?
Hi
The TI82 is a bit old Technology and if you did not use for a few years the screen is dead its a common problem with this model and the TI83
sorry for not been a big help
Oct 21, 2010 | Texas Instruments TI-82 Calculator
I have a TI83 Plus . Its been inactive for over year. I replaced the 4 AAA and the CR battery. The unit will not start. It does nothing. What can I do?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Mar 18, 2010 | Texas Instruments TI-83 Plus Calculator
I own a TI-83 Plus that just quite one day. I replaced the battery and still nothing. The display never recovered. Between my son and daughter and I this is the third TI-83 Plus that has had power circuit...
When you change the batteries the display reverts to default setting. My optimistic guess is that the screen display is so light that you cannot see anything on it. This can be arranged.
A Try this before thinking of repairs.
  1. Push the ON button.
  2. Even if you see nothing, press the [2nd] key and release it.
  3. Press and HOLD the UpArrow key until the screen darkens.
  4. You may have to keep pressing UpArrow for a little while before you see anything.
B If that does not work
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. Whileholding [CLEAR], reinsert the AAA battery and then
  4. turn the calculatoron.
  5. The calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
C. Third option
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary.
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cables ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. Whileholding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
If all else fails you can contact Texas Instruments at ti-cares@ti.com
Hope it helps.
Thank you for using FixYa.
Nov 19, 2009 | Texas Instruments TI-83 Plus Calculator
I received this solution, but at the end the calculator asked me about some invalid certificate. Now the ti 89 is stuck at the boot screen because if I retry, it goes thru the whole process again and asks...
The answer I gave you was taken verbatim from the TI FAQ and knowledge base. I copied and pasted the part relevant to you calculator.
In any case, I sent an e-mail message to ti-cares@ti.com, giving the link to your original question and my answer to it. I took the liberty to copy/paste your present message. I also asked about that invalid certificate.
All we can do know is wait for their reply.
k24674.
Oct 31, 2009 | Texas Instruments TI-89 Calculator
I changed the batteries and now it will not come on
Here it is from the horse's mouth (TI Knowledge base)
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83 or TI 84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
Reinstalling the OS for the TI83/TI84 Plus family
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TIConnect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
Hope it helps.
Oct 11, 2009 | Texas Instruments TI-84 Plus Calculator
Turn-on woes My TI83 will not turn on. Batteries new and installed correctly. What gives? Khumalo
Take out the AAA batteries and hold the on/off key for thirty seconds. Replace the batteries and it should come on. If it doesn't remove the backup battery and the AAA batteries and hold the on/off key for another 30 seconds. Replace all batteries and turn it on again.
Oct 13, 2008 | Texas Instruments TI-83 Plus Calculator
TI83 Troubleshooting...
Maybe I can help you. I don't know what Josh did. But email me if your still interested. raklein62@yahoo.com
Sep 10, 2008 | Texas Instruments TI-83 Plus Calculator
Toshiba e310 no reset
When it is reset the screen is just a series of vertical lines or just plain white. if it beeps it isone quick beep.
It appears to do things when you move the stylist over the screen yet can't go to the main screen.
I have followed factory reset (switch off then on), (reset power till screen on then release power), (disconnect power plug from battery to board). NOTHING worked
Jan 24, 2007 | Toshiba e310 Pocket PC
Texas Instruments TI-83 Plus Calculator Logo
471 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
