Question about Lexicon Omega Desktop Recording Studio Sound Card
As soon as I plug in/switch on my midi keyboard, the USB LED flashes
I recently purchased the Omega and am pretty new to home recording. I connected my midi keyboard up to it a few days ago and everything worked fine. The last few days, I've had problems. Every time I connect the midi keyboard, the USB LED starts to flash on the Omega and nothing works. I don't know why it's suddenly happening as I'm sure I've done verything exactly the same as the day it all worked.
I've tried re-setting the Omega and restarting PC, etc. I've also Googled this problem, checked relevant forums and not found any solutions anywhere online.
if anyone knows the answer, please explain in simple terms as I am new to this and not very technical. Thanks a lot!
p.s. I'm using a desktop PC with Windows XP.
  • 3 Answers
Dear sir,
your problem is very simple. please check the didi key board seriel pin.some time the seriel pin is broken. your goole problem is network problem.please check the network connectivity. otherwise operating system problem.sometimes while your installing the operating system some files missing. so first check your computer network and serial port.
thanks & records
Posted on Aug 16, 2008
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
How to solve midi connectivity issue with Yamaha keyboard?
You will need to send it in for repair is my assessment.
Mar 03, 2017 | Yamaha Audio Players & Recorders
Connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
Aug 17, 2009 | Casio 76 Key Smartmedia Keyboard
How to fix a usb composite device?
You need to manually allocate the memory locations which is a rather complex job. Try to find a Windows-savvy techie.
Jun 14, 2009 | Electronics - Others
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
Yamaha 61 key keyboard midi usb connected but what next
Depending on what you want to do...
If it's only music Mixing, you will have to plug your keyboard via audio jack to the line in of your computer. Then Audacity (free soft) can do the job.
If you want to edit midi file with your keybord you will need midi editor software like Linux-Rosegarden or if under windows try LMMS (all free soft of course).
Good luck
Oct 16, 2008 | Yamaha Portable Keyboard
Plugging in keyboard
MIDI only carries digital information, not audio. Midi is used to communicate patch settings and note value information. If you want the recording to know the note value, then you should use midi. This is useful if you want to do things like adding rythm tracks, etc.
If your keyboard has audio/line out (as opposed to headphone out), use that, as it is matched much better in impedance. If it doesn't have audio/line out, then you can use the headphone jack, but you will have to turn the attenuation way down because the headphone jack impedance is much higher. This will tend to distort on the recording if you are not careful.
The first thing to know about digital recording is that distortion is much more of a problem. I won't get into the theory of this, just know that impedance mismatching is more of a problem with digital.
Sep 08, 2008 | Tascam 2488 Portastudio Multitrack...
Lexicon Omega USB on new HP Dual core laptop pc running vista 4GB Ram
You said the magic phrase premiume HOME computer...
and the key word VISTA.
I've heard of VISTA pro running this but the home version is really not that robust for the type of gear you have there.
vista just has to many bugs.
go back to xp pro sp2 for good results.
good luck
Jun 11, 2008 | Lexicon Omega Desktop Recording Studio...
Recording on my Yamaha CP33 keyboard using USB
We're talking about audio recording. If so you must conntect your piano by using the L + R outputs with your sound card or mixer line inputs (that's how I do this). USB is ok if you want to use your piano as a master keyboard (MIDI). Another important thing is that you must have an additional application installed called sequencer ( for example Cubase Sx, Sonar...) which will let you store your digital music. I'm not talking about the proper settings of them because it could take a day or so...:)
Overall, you will have to learn a bit about the home studio, home recording techniques. There are tons of informations on web. A great thing is that you can use your CP33 as a master keyboard to control additional virtual instruments (VST) or for example play different piano samples (check Synthogy Ivory). Possibilites are endless!
May 24, 2008 | Yamaha Full-Size Keyboard
USB Audio Recording
well its midi keybord u will need sum hi tech gear here mini box usb for your pc to get controller keybord in it thats if it has midi outs most better hi end models all have midi out need to go to guitar center buy usb interface for pc recording ok to put in midi devices ok now if u wanna get crazy u can us eyour headphone out to eth in mini jack into your sound card in but most sound cards dont have software to record only x fi sound blaster higher end models will creative recorder program u can use that to record what u here from aux in jack save as hi end mp3 then drag drop to nero to burn a cd ok got all that
Dec 05, 2007 | Ahead Software Nero 6.0 (60045) for PC
Open Questions:
See all Lexicon Omega Desktop Recording Studio Sound Card Questions
Lexicon Omega Desktop Recording Studio Sound Card Logo
226 people viewed this question
Top Lexicon Computers & Internet Experts
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
