Question about Philips DVP5140 DVD Player
Accessories I have a DVP3120 but cannot find a scart lead or any other input output leads, should there have been these items with the appliance?
  • sallysearby Dec 26, 2008
    I don't know what to use or how to connect my DVP3120 player to my TV and digi box.
    please help.
  • 8,596 Answers
Depends on the /xx at the end of the model # - if it is an 07, 17, or 37, it was designed for US, and will not have these - go to www.philips.com/support for the manual for this product to see correct hook-up options
Posted on Sep 04, 2008
I am trying to copy VHS to DVD [using quality DVD-RW] but keep getting screen message of NO SIGNAL - Please check connections.
Hi try this set up to check if you're scart set up isn't the problem connect 3 rca lead to the output of the vcr into the input of video recorder then plug 3 more leads from output of video recorder into the TV set you're TV to AV INPUT AND set YOURE VIDEO RECORDER TO THE CORRECT INPUT MODE ...good luck
Aug 03, 2015 | Televison & Video
I have a THS220 box and have difficulty recording programmes
Hello Joan,
To record a satellite you will need two scart leads.
Plug one end of the first scart lead into the "DVD/VCR SCART" socket on the back of the satellite receiver, then plug the other end into the "INPUT" scart on the back of the VCR. Take one end of the second scart lead and plug it into the "OUTPUT" socket on the back of the VCR and plug the other end into "SCART IN" socket on the back of the TV.
To record, select the satellite channel you want to record, then, on the VCR, select scart input, (at this point, you can record a satellite program). To watch a satellite channel or recorded satellite channel, select the scart input on the TV.
If you need anymore information, then let me know.
Kind regards,
Ron.
May 04, 2014 | Thomson Audio Players & Recorders
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
Ineed to know how to interconnect our tv, vcr, dvd and top set box, Can you help? Philips DVP3120/05, Philips VR720 Philips 282 tv with built in dvd and Bush free view top box.
Problem solved : incorrect connection of scat leads Solved by roof top digal aerial Digi top box and on to VCR. and then on to TV.
Scart from VCR to TV
Scart from VCR to DVD
Scart from Digi Top Box to TV.
Everything now functions correctly
Equipment connected:
Philips VCR: 720/07
Philips TV : 28PW6515/05
Philips DVD: DVP3120
Bush top box
Nov 20, 2009 | Philips Televison & Video
I have just bought a DVD Video Player No DVP3120 from Tesco it only had the power lead attached,should there have been a scart lead included. Hope you can help. Thankyou. B. F.Oxley
problem sorted found out they do not include scart leads,which i think a bit bizzare had i bought it for a xmas present it would not hve worked !
Dec 04, 2008 | Televison & Video
Cable hook-ups for TV, Satellite Box, DVD, VCR
Use SCART lead from Sat. box to VCR input( so you can record progs.) then another SCART lead from VCR output to TV set AV1 input. Connect DVD (player only I presume) direct to AV2 input of TV set using another SCART lead.
Hope all this works O.K.
Note:- If DVD is also a recorder then you don't need VCR as a recording device and leads will need to be altered accordingly, of course!!
Nov 22, 2008 | Kenwood KR-V7080 Receiver
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Dvd video player model no DVP3120 unable to get player to play on tv setting AV1 at all but on tv setting AV2 player plays dvd`s but picture only no sound. it is connected using a Scart lead.
through a process of elimimation I identified the problem as a faulty scart lead
replaced lead and all was okey dokey
thanks for advice posted
colin the cat
Jan 22, 2008 | Televison & Video
NEW DVD PLAYER, PHILLIPS DVP3120 PICTURE SCROLLING RIGHT TO LEFT
have you tried the scarts they are fully inseted to dvd and also the tv , some times the cables become loose this can cuase this to happen .
riz.
Nov 20, 2007 | Televison & Video
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Philips DVP5140 DVD Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
