Question about Gestetner DSc224 Copier
Gestetner DSc224 starts to print black strips inside colorpages
Hi, i got a Gestetner DSc224 (also Ricoh aficio 1224c) with a duplex unit.
The printer starts after about 150 full color duplex pages to print inside the color printet areas to mix the colors up. The not printet areas on the pages are still white, but where is color, the color looks like the printer added some black. Both waste toner cartiges are emtied freshly and the 4 Toners are original Ricoh Toner. After about a 30 seconds printbreak the streaks are gone but reapear on the 3rd page again.
And as well there is on the top of the pages are black spots, as if there is a toner hil on a area and falls of becaus of vibration. but as with the problems befor, after a short break its gone and reapers on the 3 page.
the pinter has about 80.000 black prints and 10.000 color prints.
thx a lot for your help.
manne
  • Anonymous May 11, 2010
    Have you had this machine from new? When was it last serviced?
  • 211 Answers
The printer in the service program has a option for the printer to do a process control on selected number of copies that number for your machine should be lower because you print about 150 duplex pages an that is 300 single pages so go in the service menu and set the process control on some 30 pages to be done .
Follow the next procedure:
- For to enter the service mode:
1. Press the clear modes key(the yellow key)
2. Type “107” at the numeric keypad.
3. Press the clear/stop key(red key)
and hold it down until the screen
display changes (for about 3 seconds).
4. Touch “Copy Sp” on the touch screen.
In the upper right corner on the touch screen has a key named [Sp Direct],touch that key and enter with the numeric key pad the numbers:3003 and on he screen will appear [Lubricant Interval] set the interval on 30 pages and press the "#" key for to confirm the value. After that for to return to normal mode press the exit key on the touch screen several times.
Also do the [maintenance -clean/adjust] option once after 1000 or 500 pages printed. Because this is a office machine and when you print on her a lot of pages per day the machine start to get dirty.
PLEASE RATE ME IF THIS HELPS
Posted on Jul 17, 2009
  • 1,219 Answers
Hi!
Did you change the black drum unit?
Did you check transfer and transfer cleaning blade?
It seem like you have problems with transfer blade or drum unit.
If you say that you have 80000 copies without changing any drum start with black drum unit and cleaning blade on transfer.
Posted on May 03, 2010
  • 163 Answers
Possible drum unit. or dirty sensor behind drum
Posted on May 05, 2009
  • Bernard D'Souza Jan 18, 2010
    drum cleaning unit problem
    there is a modification made on the gear which moves the cleaning unit up & down. If u buy a new drum the modification comes along with it.
    The modification is just a clip to support the gear.
SOURCE:
Black smudge when printing color
Imaging unit is the problem. It's made for 100k but often there is a problem very soon after replacing. There is a belt in this unit and he has a lenght enough for two pages A4. Thats why you have problem on every second page. Try to reassembled it and see what is wrong inside ot imaging unit.
If you ask me...buy new mashine. This one have a hundreds of problems by default.
Pifonski
Nov 23, 2015 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Dsc224 color print misalignement
This model is infamous for this. Not a job for those without experience.
Aug 27, 2014 | Ricoh 1224c 1232c Gestetner DSC224 DSC232...
Hello i have ricoh aficio 1224c color . but the is have problem error sc792 . please help me best regards Salar
SC 792 :Finisher error .
The machine does not recognize the finisher , but recognizes the relay unit .
Possible causes :Defective connector
defective cable
incorrect installation
Aug 10, 2011 | Ricoh Aficio 1224C Black and White Copier
Ricoh (Aficio) 1224c. code sc670 we want to decode this codesc670
Hi, it looks like a bad controller board. Try resetting it from in service mode with 7807. Also if you can view or printout the error history with 5990-004 for further trouble shooting. Hope this helps
Aug 03, 2011 | Ricoh Aficio 1224C Black and White Copier
I have aficio Dsc224 and i used wrong towner color i used aficio C1224 by mistake and the machine not work propebly ..
The toner for Ricoh 1224C and the Gestetner Dsc224 are the same. Here is a link to show you that the toners are the same for this series.
Good Luck and Thank You for using Fixya.
WheatlandServices
http://www.precisionroller.com/search.php?q=1224C+toner
Dec 21, 2010 | Gestetner DSc224 Copier
How do you print via computer double side print automatically with duplex on a Ricoh 1232C copier printer.? (also know asc Aficio DSC, Gestetner R032C, Infotec)
First you need to enable the duplex option in the accessories tab.
Go to printers, and sellect properties(right click) and accessories.
Feb 25, 2010 | Ricoh Aficio 1232C Color Copier
Postscript Option (PS/3 DIMM) for a Gestetner DSc224
either from a local dealer or you try and google it or Ebay
Sep 15, 2009 | Gestetner DSc224 Copier
Reset Duplex Unit Correctly on Ricoh 2232C
Hi There,
The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
Scott K.
Jan 28, 2009 | Ricoh Aficio 1085 Laser Printer
453 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
gggg
Adorjani Laszlo
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
