Question about Dryers
Maytag dryer intermittently does not heat up. Cleaned the vent, no luck. What's wrong? HOW DO YOU OPEN THE DRYER TO GET TO THE PROBLEM?
    Genius:
  • Dryers Master
  • 1,198 Answers
My Maytag has two screws on the lower front , the front will then pivot up and release. Gas or electric? How old? Older gas units can get dust on the flame sensor next to the ignitor, inside the burner area, keeping it from seeing the flame. Wipe it off. Don't bump the ignitor, it's very delicate and will break. Carefully move it out of the way if you have to.
Posted on Aug 09, 2008
Maytag dryer will heat up the first time but not again. Igniter goes on but doesnt light.
Replace both valve coils. They will open the valve the first time, but when they get hot, they become intermittent at best.
May 11, 2014 | Maytag Dryers
Heats up for short time then goes cold. Cleaned out dryer vent. removed front of dryer and cleaned out inside trap and blower between trap and exhaust
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Aug 10, 2011 | Maytag MDG2706A Gas Dryer
Need to replace the belt on a Maytag LDE210 dryer. How do you do this? I already have it open.
i just cleaned and added a new vent hose,,set the dryer back up ...now it has no heat
Jan 07, 2010 | Maytag Dryers
Maytag dryer overheating
have u replace heating sensor
Oct 22, 2009 | Maytag PYE2200 Dryer
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
Regards,
May 12, 2009 | Maytag PYG2300A Gas Dryer
MayTag Dryer Model # LDG862AAE
dryers either heat or don't heat,you must have a clog in the dryer vent and or the wall vent that must be cleaned out,let me know what you find-mike
Oct 15, 2008 | Maytag Dryers
Maytag Neptune MDE5500AY Heats intermittently
the herating element might be going bad. disconnect power, remove and inspect the heating element. look to see if its getting thin at any point. as it heats it could be seperatring and only give heat when it cools completely
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer giving heat only for shor time
if heat works, and vent is definitely not an issue, i would look to replacing the valve coils(279834), the coils heating up and not allowing the valve to re-open on subsequent tries through length of cycle. $20 repair
Mar 03, 2008 | Maytag MDG9606 Dryer
Dryers Logo
107 people viewed this question
Top Dryers Experts
