Question about Kenmore Vacuums
My 8 yr old kenmore vacuum works well - however the hose has worn under the handle where there is a hole (resulting in decreased suction power). I'd like instructions on opening the handle and bypassing the worn piece of tubing rather than replacing it for $129. Some of the handle screws remove easily but the last one doesn't loosen easily.
    Brigadier General:
  • 6,966 Answers
Have you tried spraying the stubborn screw with WD40 and let it soaked for a while? Other than these screws holding the handle together, there would no other way of opening it up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
    Genius:
  • 1,847 Answers
May i have the model no#?
Posted on Aug 09, 2008
SOURCE:
Meile vacuum s3121
push a broom handle through it or a peace of hose pipe
Nov 23, 2013 | Vacuums
My new Kenmoore Powermate 116 canister has poor suction. I have no pets and light dust. Its not picking up small particles on the wood floor with the floor attachment. When I put my hand to the suction it...
First of all disassemble the handle and hose as much as possible and examine the inside. Make sure there is not any significant debris lodged in the hose somewhere like a plastic bag or something.
Also check at the top of the pipe right under the handle and power switch for a circular plastic ring that rotates round the metal suction pipe. There is an empty slot in the steel pipe underneath it and in one orientation the hole in uncovered thus reducing the suction for use on delicate items like drapes. Just check that that plastic ring is rotated to the closed (full suction) position.
If you have any questions or require further assistance please comment back here on this page and I will endeavour to help you.
If this was at all helpful please click on the 4 Thumbs Up rating icon above.
Thank you very much.
Joe.
Feb 15, 2011 | Kenmore 23912 Progressive PowerMate Bagged...
I have a Kenmore "Intuition"
I had a different vacuum that did this. I took all manner of things apart looking for blockages and the like .I found that by having the vacuum handle in the full upright position shuts off the suction to this area and doesn't power the brush BY DESIGN. I think this is to get more suction to the hose.
Dec 18, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Very poor suction.No obstructions in hose.Just cleaned filter and emptied canister.
Are you getting good section at the wall inlet? If so, see below.
Check for a clog inside the power nozzle. Detach wands and drop a small coin into connection. It should fall through. If it doesn't, there's a clog that needs cleared.
A leaky hose could be the problem. Any vacuum hose is often mistreated, though intentionally. But due to the length of the CV hose, it undergoes quite a bit. Being constantly dragged around corners and pulled around, as well as improper storage can all result in holes/leaks in the hose. A few tiny holes throughout the length of the hose will result in an often dramatic loss of suction.
How old is the vacuum? It may be time to replace the hose.
Nov 22, 2010 | Electrolux Central Vacuum
Poor suction in system - I have used shop vac to suction all three receptacles. Have checked bag and cleaned everything. Still poor suction. I have one receptacle in garage that works perfectly. Must...
Have you checked the hose for clogs or leaks. Clogged and leaky hoses are an area of concern with any central vac. Unless you hose has a hose sock, then wear and tear from constant rubbing on floors and other surfaces will result in holes and cracks. Pulling the hose can also result in leaks where the hose attaches to the handle and intake connector.
Mix some dish soap with water.
Use shop vac to blow air through hose, with other end capped or "clogged".
Apply soap solution to each end of hose.
If bubbles form, this indicates leakage. Hose will need to be replaced.
Oct 25, 2010 | Broan-NuTone CV450 Central Bagged Central...
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Decreased suction
you might have a clog, to try and unclog the lines, you need to unplug the unit, and remove the bag compartment. Then take a shop vac using the hose attachment hold it into the attachment door where there is low suction and try to draw the clog out the way it went in.
May 09, 2009 | Broan-NuTone CV353 Central Vacuum
Mdy vacuum is losing power on the canister and the power is still in the power head.
YOU DON'T MENTION THE MODEL OR THE AGE OF THE MACHINE. TAKE THE HOSE OFF AND PUT YOUR HAND OVER THE HOLE TO SEE IF THE SUCTION IS STRONG THERE.IF IT IS YOU NEED A NEW HOSE.
I JUST REPLACED THE HOSE ON MY 28 YR. OLD ELECTROLUX. NOW THE SUCTION IS THE WAY IT WAS WHEN NEW!
IF THAT DOESN'T WORK, WASH OR REPLACE ANY AFTER FILTERS.
GOOD LUCK!
Apr 26, 2008 | Vacuums
Main vacuum suction won't turn off
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
