REGION FREE CODE FOR THE ASDA/DURABRAND LEDVD0802 DVD PLAYER, CAN ANYONE HELP PLEASE?
  • burnzie Sep 19, 2008
    I have the same problem, anyone help ?
On the setup screen, 3rd to the right, if you put in 1379 it shows the region code, but I can't figure out how to change it.
Posted on Oct 11, 2008
Help Toshiba SD 412V DVD player, Region Free
i am not aware of any product to do what your asking? however if you buy a cheap player from Walmart/Asda that has "DIVX" on it for about £30/$25 dollars it will play all regions.
Jul 30, 2009 | Audio Players & Recorders
New dvd player
Check your TV setup, especially scart socket/AV menu. It is possible your scart menu is on av priority.
Ali
Jan 24, 2009 | Durabrand DVD-1002 DVD Player
AWA DS-A331 DVD PLAYER REGION CODE
(1) Open tray with remote
(2) Enter 0,5,2,0 on the remote
(3) Press up, down, left then right
(4) Press 0
(5) Close tray
Dec 30, 2008 | Televison & Video
Displays "No Disc"
It can be several reasons
1. Disk is upside down
2. Lens is durty. CD/DVD cleaning disk will help
3. Disk is in different formate (for instance NTSC for US but you trying to playback disk in PAL)
4. Disk has different region code (look is the dvd player and disk have the same code, or ALL Regions code)
Good Luck
Dec 26, 2008 | Durabrand DUR7 Portable DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Durabrand pdv-709
Turn Player On
Open Disk Tray (Leave Open)
Using the Remote Control Press 3 5 9 7 3 5
Select 0 (Zero) For Region Free (MULTIREGION) or 1 ~ 6 For Region Specific if Required
Dec 03, 2008 | Durabrand PDV-709
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Dvd region code
switch on.
open lid.
press STOP on remote.
enter code 2379 on remote.
region code list will appear on screen, using the UP/DOWN buttons on remote select required region (9 is multi-region).
press OK on remote.
close lid.
press STANDBY on player
OR
1. Power ON
2. Open Tray
3. on the remote use the code.
359735
4.Use region 0 to make player region FREE.
May 20, 2008 | Durabrand DVD-1002 DVD Player
Televison & Video Logo
584 people viewed this question
Top Televison & Video Experts
