Samsung v25 my samsung v25 will not turn on there is a light on the right hand side of the laptop indicating that the power is full however when the button is pressed to switch it nothing comes on my laptop screen (there is no display the screen remains black as if it is switched of)
the machine does the same as described above. it seemed to occur when i plugged in an external hardrive that has been tested on other computers and is fine, after pressing the on button it the fans dont spin up and there is no HDD activity
You can't post conmments that contain an email address.
1. Turn it On your Laptop
2. If you have CRT Monitor? connect it to your Laptop if they have screen appears.
3. If they have display your LCD have a problem.
No power to the glow plugs means no power to the light also. You have a bad fuse or connection to the glow plug relay. Fix that and your good to go. Has nothing to do with your indicator lights on either side of dash. Glow Plug power indicator is labeled THAT and only that.
Hello Mark Hold down the Fn key and press the F key which should have a wireless icon on it. Seen as its Christmas and i also live in good old Yorkshire, if you still need a hand when it comes to the day email me at [email protected]
her i think your problem is on operating system(OS) lavel and u need to recover yr os with recover dvd or recover disk whitch provide with yr laptop and if you need to reset factory setting you have to go on bios setup screen
1 start laptop
2 press F10 button
3 then go to last screen ad find " setup defullt opetimeze"
4 then got to save and exti button
simple.. if u need more help please contact feel free.. thianks..
Turn upside-down. Remove screw in the centre marked KBD.
There are 4 screws running along the back. Remove the 2 inner ones.
Lever up the keypad with a small screwdriver - Careful not to disconnect the ribbon underneath.
Undo the 3 screws along the strip above the keyboard and remove the strip.
VGA connector is next to the power button. Check it is pushed down firmly.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
