Canon MP-25DV Calculator Logo
Posted on Aug 09, 2008
I have the same problem I can not change date and time
In the model mp11dx how I fiz the problem
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
837
Points
6
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
NOTE: If unsuccessful attempts to set the date and time have been made,
please first confirm that the piece of paper/plastic in the battery
compartment on the bottom of the unit has been removed. Then reset the
unit by inserting the tip of a ball point pen into the "RESET" hole on
the bottom of the calculator. The calculator should be on and in the
"Print" mode so that you can hear the calculator reset.
How do i set the date format for my canon mp11dx?
  1. Turn the calculator on and press the Calendar/Clock button which is to the right of the FEED button. ...
  2. Select either the Calendar or Clock mode, then press and hold the "Equals" key for three seconds.
  3. When the first number of the Calendar or Clock display starts to flash, enter the date or time.
More items...
Canon MP11DX Printing Calculator > Customer reviews
52helpful
2answers
How do I set the date for this Canon MP11dx? I
Start by pressing down on the clock/calendar button for about 3 seconds. Then press the equal ( = ) sign to input the correct date. Same process for setting the time. then press the ce/c button to clear the data on the screen. When u want to print the date, press the calendar button. this will automatically print it. then press the ce/c button again so u can start calculating.
Enjoy!
4helpful
How do I change the date on the Canon MP11DX calculator?
Check the user manual here
I searched this for you, pls leave a good rating
6helpful
MP11DX time and date will not set
I just did it over and over again, I think I may have even hit the = afterl. To change the AM hold down the calendar key, then the div
193helpful
7answers
Canon MP11DX
press the date/time button
press and hold the = button
once blinking set the date
press the = button again
once blinking set the time
the "x" button changes A / P
press the + button again
139helpful
6answers
Canon P170-DH
I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
278helpful
7answers
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
old marine
old marine
ZJ Limited
ZJ Limited
