Question about JVC Cameras
I have a JVC GR-D72U camcorder. The dv tape will not eject when the cover is opened and the camcorder display is black.
  • g_desrochers Aug 09, 2008
    Is there anything I can do to fix it?
    Master:
  • 521 Answers
It is the problem with the gears
gently open the screw and disassemble the front unit and apply the greese material between the gears so to move them frequently. if the gears are damaged you have to replace the gears.do not forcibly pull it out it will damage something else of the unit.
Posted on Aug 09, 2008
  • tech expert12 Aug 14, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
    Genius:
  • 1,847 Answers
The tape seem to be struck between the gears.
  • 1 more comment
  • Legin Varghese
    Legin Varghese Aug 09, 2008
    Can't you turn the loading motor pulley with your fingers? It's that
    short gear that turns the horizontal cam on the right in front of the
    A/C heads. Going one way will unload it, the other loads it. Be
    prepared to wind the video tape into the case by hand before the
    casing door shuts or it be crinkled. Another method is to remove about
    4 screws holding down the basket but then you must preserve the
    timing
    http://www.intrepid-video.com/database/j...
  • Legin Varghese
  • Legin Varghese
Jvc minidv cassette not working display saying end tape does this mean tape has come loose.
End tape means that you have recorded the full 60 standard play or 90 minutes long play and you should rewind the tape or eject it.
Oct 15, 2013 | JVC GR-DVL100 Mini DV Digital Camcorder
JVC GR-D72U SCREEN READS ''UNIT IN SAFEGUARD MODE, ETC.). Also tells you to eject and re-insert taspe. Nothing helps. tonyramutis@aol.com
Something going on with the mechanism most likely.. It needs to be looked at, might need the mechanism replaced, or a more minor mech repair.
Apr 05, 2009 | JVC Cybercam GR-D72 Mini DV Digital...
Jvc mini dv GR-D72U
No Prob...I had the same problem with my GR-D72U. There is a defect in the CCD image sensor. JVC will fix it for FREE! All it will cost you is shipping it to them. Go to http://www.jvcservice.com/service/CustNoticeCamcorder.asp?PgReq=DspDtaDtl&MdlNbr=GR-D72US&Pgm=CCD , download the rapair request... Send it off to your nearest service center and they ship it back all fixed up in less than a week. I must tell you though, you ONLY have until Dec. 31 2008 to do this. Not only did they fix mine, they cleaned the heads but also buffed out a scratch. After you get yours fixed, post as many helps as you can to others.
Sep 05, 2008 | JVC Cybercam GR-D93 Mini DV Digital...
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
Jvc gr-d72u
use firewire cable from your dv port to stream video-4-4 pin for laptop 4-6 pin for mac or tower
May 17, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Jvc gr d72U
mi problema es q no tengo sotware para esta camara gr-d72u
May 13, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
Jvc digital video camera gr-d244u mini dv
My jvc gr d244u digitial camcorder it torn up. when i go to eject the tape and it pops out it want retract it back in. what can i do to fix this problem.
Jan 04, 2008 | JVC GR-D244 DV Digital Camcorder
Jvc GR-D250
There is any error code showing on the lcd screen?
Oct 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Jun 06, 2007 | JVC GR-D270 Mini DV Digital Camcorder
Cameras Logo
107 people viewed this question
Top JVC Cameras Experts
Parshiv Luthra
Are you a JVC Camera Expert? Answer questions, earn points and help others
