Question about Lenovo 3000 C200 Notebook
Hardware problem - not booting into windows
I've been using the laptop without any problems untill i encountered the folowing ERROR: [email protected]#$
Error 0701: USB Over Current On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00H
Error 0701: USB Over Current On HC/Port - Bus:00H Dev :1DH Fun:02H / Port:00H
Press F1 For Setup, Press F12 For Boot Device Selection Menu
Well, F1 takes me into the Bios, all looks well. And F12 Does nothing. how ever i tried to boot from CD-drive but of no use, i tried to solve it million methods but invain i couldn't if any one has a solution for this please provide i'll be very thankfull
thanks in advance
srini
  • 94 Answers
Tosrisri hello,
If you have a VISTA DVD, please insert it, and use the BIOS to boot through your CD.
Then, when the VISTA installation comes up, press repair. Restart, and try again. Please report back.
Posted on Oct 29, 2008
SOURCE:
Hello, Im having a problem with my Dell INSPIRON 1750.
it's possible your hard drive has gone bad, that's what it sounds like
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Aug 02, 2012 | Dell Inspiron Computers & Internet
My sistam is not restore ... WHY???
This error code usually points to an installation of windows that has been corrupted. I'm assuming that you have no USB flash drives plugged into the laptop when booting, if so, remove these and try a reboot.
Then try to boot to safe mode (f8)
If this fails, boot from the CD drive by setting the DC boot option as 1st boot in the bios, put the windows installtion CD in the drive and go through the install proceedure, selecting the REPAIR option.
If this fails, you will need to reinstall windows.
To recover any lost files, after reinstalling windows, download a utility such as recover my files and set it to a format recovery to get any lost files back.
Jun 21, 2012 | Samsung R530 22GHz Intel Core Duo...
Dell latitude e4200 restarts with blue screen
Sounds like the image doesn't have the right drive controller driver included. Could be because the image was created on a different laptop or could be the drive controller is configured differently. You can confirm this from the STOP error code on the blue screen
Go into the BIOS setup (probably F2 at boot) and see if the controller mode is set to AHCI. If so, set it to compatibility or combined(?) and try again.
Either way, if you've installed an image for the wrong hardware, you probably should do a remedial install. Boot from your Windows XP disc and follow the prompts as if you were doing a clean install until you get to the license agreement. At the next screen, it should show you any existing Windows installs and give you a new option to repair. Let this go - it won't touch any user files, just replace all the Windows files with those from the CD. Have your system drivers and service packs handy to tidy up when it's done.
Apr 10, 2012 | Dell Latitude E4200 Notebook
Why the caps lock and scroll light keep on blinking without entering to the window
The lock leds are used by some computer manufacturers as an error indicator. if you are unable to boot up and the lock LED's for caps and scroll are constantly flashing then it would indicate that your computer has most likely encountered a hardware error preventing it from loading. if you can add a comment with the manufacturer and model of your computer I can help you check the error
Mar 26, 2011 | Computers & Internet
HELP! Cannot start my laptop.
This is a classic BSOD caused by a bad hardware driver. Until you can boot in safe mode, you're screwed. Keep trying F8.
Dec 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
The laptop encounters a PCI error and will not boot
Like the Jonas brother said, it's difficult to diagnose this one without actually seeing it. That being said, you can always save some money by messing with it yourself. Personally, I'd probably look at a bootable CD next. You may have to get into your BIOS and change the boot order to reflect the CD first.
If you can get a CD to boot, you've got a problem with your hard drive - although it's probably a software problem and not a hardware problem. In English, that means you'll have to reformat the hard drive and reload Windows. If you don't have a Windows disk, you might try loading a Linux OS. They are free (and far more stable too!) for download. If you need help with that, just post it on this thread and we'll walk you through it.
Dec 21, 2009 | Acer Aspire 3100-1405 Notebook
Compaq Presario 2800 boot error
tried F8rapair your computer and startup repair and system restore...
Jan 23, 2009 | Compaq Presario Notebook
One of your usb ports is either damaged or has an object stuck in it causing a short. Unplug all usb devices and look at each port. Note if one looks slightly different from the others. There is a plastic tab that fits into usb plugs. If this tab is bent and touches the side of the port, it can cause the short. If this is the case you may be able to either clean out or bend back the bent tab.
Sep 08, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 C200 Notebook Logo
518 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
