Needs help
hi,if your leance could not open when you turn on camera so may be you must cheak the lence assembly breckeg , if the lence is open then servise lence unit and fix it properly,and the easy way is remove the lence unit and first remove moter from it and rolling well as possible.it must be smoth rolling between beralls of lence,then roll the moter alone well by using adapter about 5 volts,now fix it by aqurat ,you find a magic
my samsung L830 camera has jammed with the lens ...
