SOURCE: i typ the address that i want to go to and it
Mine started doing the same thing about 2 weeks ago and I just got around to reading if there is a solution but it appears it's a common firmware issue. In the meantime to get around the problem, you can enter the address into your address book and then it works like normal
SOURCE: My GPS Magellan SE4 say
You will need to reset your device, Locate the button marked "Reset" on the left, right or bottom of the unit.
Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
If the unit does not reset, immediately press the button again and hold it for up to 10 seconds. This will fix the abnormality.
SOURCE: i put my gps in my carfor 2 days & third day
This is normal, sense they are are all controlled via safelight and computer , they are constantly updating. I recommend once a month you manually reboot gps, to keep bugs out as well as accurate speed and performance. To manually reboot, turn off like normal, but when turning on hold on button down and keep down through opening process for about 15 seconds then let go of on button. Then is cleaned up and rebooted. Thanks mike from fixya
SOURCE: message on gps says, your
This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike.
Please don't to vote or rate this , if I helped you. Thanks Mike
1. From the
Main Menu screen, tap the Settings icon .
2. Tap
System.
Setting Languages
1. Access the
System Settings menu (above).
2. Tap
Languages.
3. Tap on the desired language.
4. Tap the back arrow .
5. The Magellan RoadMate receiver will reboot if you change the language.
Setting Auto Power
Auto power is the duration of time that the Magellan RoadMate receiver remains idle before turning off
automatically.
1. Access the
2. Tap
Auto Power.
3. Tap on the desired duration.
Setting Brightness
1. Access the
2. Tap
Brightness.
3. Tap in the brightness slider to set the brightness of the display.
The
Dim on Battery Power option will prolong battery life by dimming the display while using internal battery
power. Check to turn this option on.
Setting the Time Format
1. Access the
2. Tap
Time Format.
3. Tap on 24 Hours or 12 hours with am/pm.
Selecting the Time Zone (daylight savings on/off)
1. Access the
2. Tap
Time Zone.
3. Check Auto Time Zone or select your time zone from one of the cities in the list.
