Question about Cooktops
How can you tell which fuel a gas cooktop is set up for?
In one of your answers you stated that the person needed to make sure the cooktop was set up for the right fuel (lp/nat gas)
How do you do this by looking at the unit?
I have low flames for the btu ratings of the unit and the burners seem like they are starved for gas. I have natural gas supply that has been checked for blockage although not for pressure.
    Scholar:
  • 150 Answers
The gas regulator has a round "plug" in the middle of the top and one side is marked nat an one is marked lp you can tell which fuel the regulator is setup for by inspecting this plug. the orifices for the surface burners are marked with thier sizes (.073) for instance which I believe is thousandthsof an inch. also the orifice "spuds" as they are called will often have a drop of colored paint on them to further identify them for installation in the correct burner. checkyour carburation too. if the flame is noisy and trying to shoot up of the burner you could be getting too much air. close the air off a bit till you make a pretty flame two tone blue no yellow.
Posted on Aug 10, 2008
Hob igniter not working
Handbooks are available from Miele online. If that doesn't give an answer, you may need an appliance service person. I don't recommend you poke around yourself unless competent with gas and electrics.
Jul 21, 2014 | Miele Cooktops
Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
Brandon@Stonerepairman.com
406.471.0000
Mar 25, 2011 | Jenn-Air 30 in. Expressions CCGX2420 Gas...
How do I convert my maytag CSG7000CAB gas cooktop
i NEED TO DO THE SAME TO MY MAYTAG COOKTOP DID YOU FIND THE ANSWER YET?
Mar 08, 2010 | Maytag MGC5536 Gas Cooktop
I cleaned my viking 6 burner gas cooktop and now there is no clicking and nothing ignites, but I smell the gas coming out - Anyone know what to do?
how u clean it,u think you never damage the gas line? call the person how to resolve the gas leak if we have.
tnx.gerbee
Sep 12, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Propane conversion
All gaq cooktops come from the factory ready to be installed to natural gas. If the only gas available is propane the orifices have to be changed. The orifices are product specific and must be ordered for your particular stove.
That being said, if this is a new cooktop you have the answer. If this is a used cooktop and you do not know which style of orifices are installed now just contact your propane company and they will be happy to help you for free.
good luck with this. and please remember to rate my answer.
Feb 12, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
New lp gas reg needed
hello Michael - I recommend that you call your propane provider. They will be able to help you.
please rate my answer. thanks
Jan 22, 2009 | Dacor Preference SGM365SS Gas Cooktop
Gaggenau 5 burner gas cooktop, natural gas
make sure unit is set up for the fuel you are running (lp/nat)
make sure connections are correct and valve is 100% open no blockages anywhere if all good call for wty service you don't want to void wty on a new unit
May 15, 2008 | Cooktops
Gas cooktop BOOM
Gas is taking too long to ignite. Make sure the burner rings are installed properly. They have grooves that need to line up. Also make sure all the holes are clean.
Apr 03, 2008 | Cooktops
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
Cooktops Logo
193 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
