Question about Medion Computers & Internet
I have purchashed additional ram (ddr 400 pc3200 1gig) after installation the pc locks up and informs that new hardware has been found! what do i do next?
    Scholar:
  • 53 Answers
Generally this will happen when you install the RAM with diff specifications or unsupported size (MBs).
Points to be noted before replacing the RAM:
* Maximum memory supported by your computer.
* Memory specifications compatiblity.
You can get the memory module specfications of your computer from its manufacturer.
If this is happening even after installing the correct RAM then you have to try with diff brand RAM.
While manufacturing the RAM, they have to follow many standards. If they won't follow those standards, then this issue may accout. So, check with another brand.
Pls reply if you need more information
Posted on Aug 09, 2008
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I need to buy memory for my computer its an emachines desktop model# T3410 512 MB DDR SDRAM and I dont know what to get
in DDR ram there is some models like ddr and ddr2 and another new model is DDR3. First you check what is your ram related to. for that in some pcs bios option system information the details are there. For that at the time of booting before windows logo press the button whatever is showing to enter setup. and check otherwise remove your ram and take that to a computer shop and take a new ram with same model.
And one more thing is you have to check your clock speed of your ram. Remove your ram from pc and check if any information is there on ram
Jun 24, 2010 | E-Machines eMachines Desktop PC
Upgrade RAM
DDR 1 - 1 GB costs around Rs 1500 DDR 2 - 1 Gb costs around Rs 1200 DDR 2 - 2 Gb costs around Rs 2200
I just upgraded my system to 2 Gb ddr2.
You can order it on ebay.
Mar 29, 2010 | Lenovo 3000 Y410 Laptop
RAM compatibilty
No, DDR 400 will not work. The best thing you can do is call Dell and give them your information. Model number and that kind of information and let them tell you what kind of ram you need. If you put the wrong type of ram in your machine it could cause major damage. There are so many different kinds of memory out there, not to mention high and low denisity. Your machine may use PC2700 high density and if you try to use PC2700 low density it will not work. One other thing that you can try is uninstall a stick of your ram and write down everything on the stickers and then go to some place like kingston memory and use their memory locator to find what you need.
Dec 01, 2009 | Dell Dimension 2400 PC Desktop
Does P4MFM supports DDR 1GB 400 Mhz RAM
It should support dual channel (two matched sticks) at 400 Mhz and regular pc3200 1 gb single sticks
If you can go with dual channel its is faster even if it does cost more
If you found this information useful please click below
Aug 12, 2009 | Computers & Internet
Pc keeps rebooting
Try re-installing the operating system. It is possible it possible OS is not installed properly. (ehteshamhusain@gmail.com)
Jul 19, 2009 | Computers & Internet
I have upgraded my k7s8xe with athlon xp 3200 cpu. I have adjusted the jumpers to fsb 200 & installed 1gb ddr 400 ram. system keeps rebooting os vista enterprise. any suggestions. also can i install 2...
First of all, if your FSB is set to 200mhz, the system will not support DDR400. "CPU at FSB 200MHz mode, it will NOT support DDR400". The FSB will have to be either 333 or 400mhz in order to utilize DDR400. Only 1GB of DDR400 is supported. As to your rebooting issue, could be because of these incompatibilities and/or you did not properly seat the heatsink/fan on the new CPU, which also means you might not have properly applied thermal compound or might have no applied it at all. All the compatibility information for this motherboard can be found at: http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Upgrade of RAM
184 pin DDR DIMM is the correct information :) The bus speed of the ram would range from PC 2100 - PC 3200. I assume the Max amount of ram will probably be 2gb though unless your motherboard specifies a higher amount.
Mar 22, 2009 | Computers & Internet
Please help me in my RAM
If your PC boots up successfully and load windows then its mean that RAM is working fine... There is some problem with OS settings.. So at XP booting press F8 for start-up menu and select Last known good configuration... Hope it will work...
Please Rate .... Thanks.
May 14, 2008 | Intel Motherboard
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
Computers & Internet Logo
125 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
