Question about HP PSC 1410v All-in-One Printer
Msg 'unable to start print job, is printer available'
My printer works fine until I attempt to print a form sent to me via e mail, it is a pdf file and I keep getting the above message, why is this?
Thanks.
A customer called me with the same msg. Let me explain first what the problem was..they had a Graphic PDF that on the HD was 20 MB but when extracted was well over 200 MB..first I had thought the pdf was exeeding the Printers memory but after testing it was not. The customer was printing the document using adobe PRO I had him print the document in reader 8.1 and made sure the print as image under advanced was selected and the document printed..
Posted on Nov 18, 2008
Try installing ADOBE READER 7
Adobe Reader 8 is sucks!
Posted on Oct 04, 2008
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Cancel print job with a linux operating system
    HI,
    You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
    The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
    In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
    If it does not print within this window of time, do the following.
    1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
    2. You will see your print job located there, with other information, including its status.
    3. Select the job by right clicking on it and select Cancel.
    4. The job should cancel itself.
    5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
    6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
    7. You may now attempt to print again.
    Thanks,
    HP Printer Support
    Jul 16, 2014 | HP Office Equipment & Supplies
    Printer has stopped printing .pdf files
    Check your list of printers and make sure the default printer is the correct one.
    Mar 18, 2017 | HP OfficeJet 6210 All-In-One InkJet...
    I can't print pdf files from the internet, I have to "save as"1st
    Sometimes the file name assigned to a pdf is not compatible with our printer's memory. For example, if the file name includes brackets [ ] or other punctuation, or is very long, the printer won't recognize it. One print job that stalls will hold up the entire print queue, so delete your job from the queue.
    First, look at the file name displayed in the print server's list of print jobs. The same file name also appears in the top blue bar of your Acrobat pdf display. Are there brackets, per cent signs, or other punctuation marks in the file name?
    Dec 28, 2009 | Microsoft Office Home and Student 2007...
    I can't print a pdf file with officejet hp5600
    hi,
    please check if the print spool service is working or not.( start - run - services.msc)
    Sep 27, 2009 | HP Officejet 5610 All-In-One InkJet...
    "unable to print" msg
    you could try going into control panel clicking on your printer then click on printer top left and cancel all documents
    Jul 30, 2009 | Brother MFC-5440CN All-In-One InkJet...
    Msg saying unable to start print job. is printer
    Uninstall the Adobe PDF viewer and then reinstall it as the printer is respondingto other print commands,so its an issue with the s/w you are using.
    Jun 11, 2009 | HP PSC 1410v All-in-One Printer
    HP PSC 1410v All-in-One Printer Logo
    7,646 people viewed this question
    Seeker5211
    Seeker5211
