Question about Cuisinart CJK-17BC Cordless Electric Kettle
Whistling noise All of a sudden I am getting a loud whistling noise when the kettle starts to heat up. Otherwise everything works fine. Kettle only afew months old.
Sounds as if it needs descaling. Do you live in a hard water area?
Posted on Aug 11, 2008
Blend door must be stuck open. Loud whistling noise at 60mph and higher coming through dash. Very loud. 2004 GMC envoy
Take out the cabin air filter that is in the plenum behind the glove box. This will lessen the noise but you should get the unit serviced soon.
Jun 17, 2015 | 2004 GMC Envoy
Car makes a whistling sound like a tea kettle
moving noises are dangerous to find.
get help , real hands on help, an ASE mech, is such good help.
seen one do that, one was a funky license plate holder bad.
cracked plastic POS.
Dec 20, 2013 | 2004 Honda Element
My Dyson 07 still seems to be working fine but it just started making a loud whistling noise. I looked for any air leaks but cannot locate any. The whistling noice is quite loud and annoying. Are we doing...
Sorry to hear you're having difficulties with your DC07. If you've been unable to locate the source of the whistling noise, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 21, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Alessi whistling kettle -- one whistle doesnt work.
you need to replace it with a new one it will be corroded. heat kettle then drive out pitch pipe with a screw driver from below, insert new one from above.
Sep 24, 2009 | Alessi Richard Sapper 9090/1
Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
Aug 19, 2009 | ViewSonic PJ506D DLP Projector
Will not whistle
It is possible the reed valve broke.
Aug 02, 2009 | Electrolux CHANTAL Loop Tea Kettle -...
Loud whistling sound on 1999 GMC Suburban
It sounds like your Idler pully bearing or your tensioner bearing. Regardless change them both and the surpentine belt too. The sound is letting you know that the bearinf is bad and will fail soon. Good luck
Apr 06, 2009 | 1999 GMC Suburban
The tea kettle stopped whistling...
I could be that you have some debris in the hole. Try running a pipe cleaner though it a few times and see if it helps.
Mar 18, 2009 | Kitchen Appliances - Others
Code reading
replace the serp belt and check idler and tentioner pullys. serp belts make noise after antifreeze or oil has been on them. good luck
Jun 23, 2008 | 1995 Chevrolet Tahoe
Cuisinart CJK-17BC Cordless Electric Kettle Logo
596 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
