Question about Garmin Rino 120 2-Way Radio
Rino 120 Send note
I now have 4 each Rino 120 that have different programs installed version 3.9 and 5.5
I get up its menu for Mark Waypont-Fin `N Go-Enable Keylock but Send Note missing on the two radios that have version 3.9
It works quite nicely for those who are running version 5.5
I have tried and install 5.5 on those with a 3.9 but it is not possible.
I have run web Update but it changes nothing.
So now, I hope you have a good explanation of this issue and have a solution that allows me to send messages with them?
    New Friend:
  • 109 Answers
This sounds like the new firmware version may not work on the
older model.
The best solution would be to contact Garmin
Product support at (913) 397-8200 or 1-800-800-1020
Monday - Friday, 8am-5pmCDT or by email at sales@garmin.com
Pat
Posted on Aug 21, 2008
How come the garmin 120 radio isn't compatible with standard Motorola walkie talkies
When programmed to the same frequency and code settings the Garin Rino 120 should match the Motorola TalkAbout line of radios. They are all using the same UHF FRS/GMRS frequencies. Here is a link to the Garmin user guide where you will find the frequency charts on pgs. 100-102: http://www.uky.edu/~jmlhot2/courses/for480/Rino120_OwnersManual.pdf
Motorola TalkAbout user guides can be found at: http://shop.giantintl.com/Manuals.asp
Best regards.
Nov 20, 2014 | Garmin Rino 120 2-Way Radio
Menu send note missing
When you do updates it might have taken off the message option. it is just like a computer when you upgrade it will take off old programs and install the new ones... so you might check into that...
Aug 09, 2008 | Garmin Rino 120 2-Way Radio
Pc interface I updated to Garmin Basecamp and I cant down load trails or saved way points on pc, I was able to update both my 120 and 110 but program dost'nt let me receive or send to device. My 655 works...
Contact Garmin's support desk on their 800 number, or if you're not in N.Am, call their direct number, you can find it via Google. There are too many possible answers to provide quickly in this arena.
Oct 17, 2013 | Garmin Rino 120 2-Way Radio
New computer with 64-bit...can't install my current version of Compton's Interactive Bible. Is there a fix available
Install it in compatibility mode as an administrator.
1. Right click on the program's shortcut, .exe file, or installation program.
2. Click on Properties.
3. Click on the Compatibility tab.
4. To Run a Program in Compatibility Mode -
NOTE: Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.A) Check the Run this program in compatibility mode for box. (see screenshot below)
B) Click on the drop down menu arrow and select which version of Windows the program was made for. (see screenshot below)
NOTE: Always pick the latest Windows version the program was written for to have a better chance of it running properly in Windows 7.Check run as administrator.
Aug 31, 2010 | The Learning Company Compton's Interactive...
Want to use my rhino 120 with military maps
It can show this by going into the the menu [second icon] setup map, orientation/ grid setup. Change Lon/Lat Grid to On.
Apr 19, 2009 | Garmin Rino 120 2-Way Radio
Screen goes blank except a thin line
There is a firmware upgrade from Garmin that appears to address this problem for units still running Version 3.2 or earlier. If your problem only occurs when WAAS is enabled, you might try upgrading. To find what firmware version you have, from the main menu: Setup, System, then select the (options) icon on the top row, to the left of the 'X'.
Nov 24, 2008 | Garmin Rino 120 2-Way Radio
Rino 120 - Disabled WAAS
Have you upgraded from Software version 3.2? Version 3.3 addresses a memory overflow problem when receiving two or more WAAS satellites.
Oct 04, 2008 | Garmin Rino 120 2-Way Radio
RINO 120 :: screen blanks out with just a single horizontal line
Had to wait 24 hours to be able to post my own answer
By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
go down until your on the "Setup"(hammer)
go in (by pressing in, on the directional button)
go down until your on the "System"(gears)
go down until your on WAAS, go in and select the Disabled
go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
Wonder what WAAS is?
http://www8.garmin.com/aboutGPS/waas.html
Take care.
PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
Oct 02, 2008 | Garmin Rino 120 2-Way Radio
Broke rino
I had a similar problem with my account.
I pushed the one batteripolen down as it started up again.
Mar 12, 2008 | Garmin Rino 120 2-Way Radio
Peer to peer problems
There are time limits on how frequently you can send the gps coordinates.
Oct 02, 2007 | Garmin Rino 120 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
123 people viewed this question
Top Garmin Radio Communications Experts
eradiostore
eradiostore
Steve
Computer Repairing
Computer Repairing
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
