Question about Bissell Vacuums
Where to find the upper tank for model 3760C - Bissell Vacuums
    President:
  • 1,673 Answers
Here is the Bissell number, they can tell you who to contact near you.
Service Center Dept. Phone Number:
(800) 457-1509
Service Center Dept. Fax Number:
(800) 517-9535
Hours:
M-F 8:00 a.m. - 5:00 p.m. ET
Posted on Aug 10, 2008
Testimonial: "Thanks"
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
My floormate upper tank has a screw on filler cap nad the tank tank does not obviously come off the machine. The filer cap is under a hood and also cannot be used with iut removing the tank.I must not have...
Please let me know the model number from the data plate.
It is likely started with the letter "H", followed by at least for numbers.
It will allow me to post the User Manual to you.
Mar 12, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
How does lower and upper buckets work . is it the dirty water suppose to go in lower bucket or what . as i am trying to use this vac i am not able to
The Upper tank is for hot, clean water, with carpet cleaning solution mixed in at 5 ounces/gallon.
The Lower tank is the dirty water ecovery tank, hooked to the nozzle on the hood to **** up the water from the carpet.
Jan 01, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
How does it work lost instructions were does soap go what tank does water go into
There are 2 containers in the upper tank assembly. The Soap goes into the smaller one (no need to mix). Fill the other side with hot water. The lower tank is also called the recovery tank and this is where the dirty water is collected. You can find manuals for your model at the hoover web site if not the same one then any of the V2 or models that start with "F74" should work.
Oct 21, 2009 | Hoover F7431-900 SteamVac Vacuum
Whether the machine is on or off, cleaning water in upper tank empties itself onto floor within 2 minutes.
You have a hose loose that is connected to the tank or your tank is busted where you can't see it.
Jul 09, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Can't get upper tank to snap back in place after removal.
I've found on some of them that you have to stand behind the machine. Put the bottom of the tank in first, then the top, and when you have the tank in place, pull up on the tank handle so that it locks into the machine. It all has to do with that tank handle not locking into the machine. If you play with it a bit I think you'll figure it out.
Good Luck Ruth
Dec 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
BISSELL QUICKSREAMER MODEL 2070
Here is a link, don't know if it will work for you or not:http://bissell.com/images/UserGuides/1960.pdf
But you put you cleaning solution along with hot water in the upper tank, the bottom tank sucks up the water as you clean. Pull the trigger to dispense clean while pulling it back towards you, push it forward and repeat until done. If that link doesn't work, you can call Bissell and order a operator manual.
1-800-237-7691
Mar 17, 2008 | Bissell 1770 Quicksteamer II Upright...
Hoover steam-vac model #F7458-900 "All-Terrain"
Check the valves at the bottom of the tank(43513026)also check for cracks in the tank(42272104). Another thing to check is the handle asm. is a rod that pushs on the resevoir asm(tanks sits on) to make sure that it is stuck in the on position. Depressing the trigger and watching, you should be able to see if it is moving up and down ok.
Feb 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Tank for Hoover SteamVac continuously cracking
I use shoe goo or similar product to glue the cracks together. I have fixed large holes this way and it works fine. It is best done when cracks first appear. If cracks are minor then super glue might also work but if it is major or there are holes then shoo goo does the trick and it is a permanent fix.
May 30, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
61 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
