Question about Canon PowerShot S5 IS Digital Camera
Close-up picture Hi! I purchased my camera to take up close-up pictures of handmade greeting cards. The cards are 4" x 5 1/2" with lots of little details. I'd like to show as much detail as possble. I'm not sure what the best setting are? I've tried using the flash, but the whole picture just glares out, the light bounces off of the card and makes a big glare in the center. Without the flash, the picture is too dark. Can you help me figure out the best setting to use? Or, what kind of lighting I should put the card in before I try to take the picture? I appreciate your help very much.
Take photo under diffused light from sun inside the room or outdoor. Do not use flash. Try to use macro mode else adjust using manual focus(MF) mode. You will sure get a fantastic exposure.-G.Ganesh, Boisar
Posted on Oct 01, 2008
I'm not one to know EVERYTHING about cameras, but I do own a Canon Powershot S5IS & the best advice I can give you is.. to put it on 'auto' and since you'd like to show as much detail as possible.. try using the super macro. ( It's on the bottom left side of the camera) it really makes a BIG difference, you see EVERYTHING, point & shoot!
but you have to be close to it, because if not, it won't focus much
& the picture will be blurry.
hope I helped!
Posted on Sep 26, 2008
Once i insert my memmory car, and then try to take a picture, it says card protected ?
Remove the SD memory card and make sure the little slide lock id pushed forward towards the gold contacts. Then carefully insert it back into the camera so as not to knock the slide lock and close up the memory card door. Turn the camera on and go into your set up menu to format, format the card and you will be able to take pictures. Remember to format the card in the camera after downloading your pictures to the computer
Dec 25, 2010 | SVP CyberSnap912 Digital Camera
I've got a DSC-S700 that I can't get to take clear pictures, I've tried all different settings and even automatic, still get blurry pictures, it was formated when first purchased, will formatting it again...
The memory card formatting is not the problem.
There may be a fault with the camera, in which case you should return it under warranty if you can, but before you go there, have you put the camera into Macro mode? This is an extreme close up mode in which the camera will only focus on objects few inches from the lens, even using autofocus. The icon for Macro mode is a little flower.
Nov 27, 2010 | Cameras
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
The camera freezes and won't even close
This sounds like a defect. Since this a relatively new camera, Nikon will likely fix it under warranty.
However, let me ask whether you have changed memory cards since buying this camera. This camera is a little finicky about what cards you use. Try using a different card -- especially one that you have used successfully before.
Another suggestion: After you have downloaded all pictures to your computer, use the camera menu to format the card. Sometimes a corruption in the card can cause the problem you describe.
Aug 18, 2009 | Nikon COOLPIX L20 Digital Camera
I purchased a a730 Digital camera ............
Internal problems.
Call the maker at this site:
http://www.general-imaging.com/us/service/firmware.html
That sounds like it could be a ccd problem, they may fix it free.
Jul 21, 2008 | GE A730 Digital Camera
Close up shots for eBay pictures
Hi, you should have a macro lens shoot mode ( button with flower picture on reverse of camera) which allows you to take pictures close up in detail.
Jun 03, 2008 | Olympus Camedia C-60 Zoom Digital Camera
How can I take pictures of something small and detailed, like jewelry
Try using the mode that shows the icon of the flower, it is for close-ups. Also try using bright desk lamps to illuminate the jewelry well enough so that a flash is not needed. if you can, set up a white box or white posterboard to bounce light around, this too will help. Placing the camera on a tripod or something to steady it while shooting will help as well.
May 15, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Camera display shows "memory card error".
I would give this software a try:
http://www.download.com/VirtualLab-Data-Recovery/3000-2248_4-10610841.html?cdlPid=10801131
and be more vigilant about backing up your pictures. Flash memory can corrupt at any time. Good Luck.
May 05, 2008 | Canon PowerShot A520 Digital Camera
Card Locked , HELP PLZ !
Hi, I have a soloution I have literally just done it, for some reason the cards arn't going in camera far enough, get a little bit of card from a box and put it on memory card before you close the door, when u close the door it pushes the card further into the camera you can then format it and take pictures. it does work as i have just done it regards kev
Feb 12, 2008 | Samsung Digimax 4010 Digital Camera
Lines on screen
Hi, I have the same problem with my sony DSC-S700. I think someone drop it, and it took pictures with horizontal line specially outdoor. I noticed that the lens shutter does'nt open and close. All I did was to tap on the lens several times and everythings back to normal. I so happy my camera is working again. Thanks to your idea. Brenton
Sep 24, 2007 | Kodak EasyShare Z612 Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
135 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
