Question about Panasonic Televison & Video
Panasonic th42px25 require a digital tuner replacement, how to do it?
  • 1 more comment
  • japf22 Aug 09, 2008
    It's a plasma tv not a rear projection tv
    The question is how to do it, not that I need a manual.
  • japf22 Aug 10, 2008
    the part is a plug in module and does not require soldering. the part number is TNP2AA144ACS.
  • 4,234 Answers
For the sake of completeness, the part number for the tuner is: ENG36620GF and is available for $60.61 from Tritronicsinc.com. I have not seen this particular model myself, but I believe that the tuner is a plug-in module. Care must be taken when working on this set as the plasma panel is extremely fragile. The worse case is that the tuner will need to be un-soldered from another module. Be careful here too as most modules are double sides. In other words, there are conductive traces on both sides of the board. When removing the tuner be careful not to break any of the traces.
Keep us posted.
Dan
Posted on Aug 09, 2008
  • ABRsvcs Aug 11, 2008
    The part number listed (TNP2AA144ACS) is the entire module. The part I listed is the tuner that resides on the module. The entire modeul is available at a cost of $470.91 with a DUD return of $150.
    Dan
    Genius:
  • 1,665 Answers
A service manual is necesary for this repair
http://www.servicemanuals.net/service.aspx
  • 10,594 Answers
Try Here to get digital tuner for your Panasonic plasma TV.
Hope they will help you out.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Aug 09, 2008
    Another Shop here, can provide you desired digital tuner for plasma tv.
    Demand digital tuner on already provided link. If you wanna replace it by yourself, you need screw drivers to open tv, desoldering station to unsold the old tuner and solder iron and flux to sold new tuner.
    Shahid Electronics Aug 11, 2008
    Thats fine if part is plug-in module type. Just pull out old one and place the new part. Tuner can be purchased on above said weblinks. Have nice day!
Panasonic TH42Px25 screens have lines on it everything is working
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 01, 2016 | Panasonic Televison & Video
How do you re-tune the panasonic DMR E85H DVD Recorder. I have done exactly as it says in the manual and still it does not find any channels? Is it digital?
The tuner in the DMR-58H is a NTSC tuner (analog). Unless you have a low power station in your area, you will need a digital-to-analog converter box to record OTA stations. It can record analog cable without a box as well. (Digital cable will require a box.)
The manual for the DMR-E85H is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRE85H.pdf .
I hope this helps.
(at least in my area there is only one station broadcasting an analog signal; it is a low-power transmitter and thus wasn't required to upgrade to digital with the rest of the stations.)
Mar 27, 2012 | Panasonic DMR-E85H DVD Recorder
Will the Panasonic DMR-E30 DVD Recorder replace my STB to receive the digital free to air stations on my tv?
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
Oct 06, 2011 | Panasonic DMR-E30 DVD Recorder
How to transfere films from my panasonic nv-ds60 to pc
Hi
Install a PCI TV Tuner Card in your PC, connect your panasonic nv-ds60 to that pc tv tuner card, and record..
thats all
Aug 03, 2009 | Panasonic Cameras
Does the Panasonic TV Model TC-26lx50 have a digital tuner?
Hi mrfeld, The TC-26x50 has only an analog tuner, if you want to recieve the new broadcast OTA signals you will need a Set Top Box. Let me know if you need further explanation and please rate this solution. LOne99star
Jan 16, 2009 | Televison & Video
Freeview not working
The tuner may be defective, or the reception is too poor for the set. A service tech who is qualified to work on your model of set can go out to your place with some field test equipment and verify the performance of the set for you.
The tuner and or IF modules, or main video processor module may be at fault. These modules can be replaced if necessary.
Before having a service call, read the instruction manual to make sure that all the user settings are correct to recieve programs from the tuner section. You can call the Panasonic tech support for assistance.
Jerry G.
Dec 18, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Reception upgrade or what ?
Older sets are fitted with analogue tuners which can't handle digital signals. The only way round the problem is if the TV can be used as a monitor via a scart input. The external freesat or digital set top box contain digital tuners which can then display the required digital information on the TV. These external units have scart output sockets at the back, specifically for this purpose. So it's a scart lead from your external digital device to the scart input socket at the back of the TV. The remote control for your external box is then used to select the required programmes
Oct 24, 2008 | Panasonic Televison & Video
Digital TV
It does have a tuner built into it.
It is not a hd or digital tuner.
manual
<A href="http://www.uwsp.edu/cps/facilities/classroom/manuals/VCR/PVD4752.PDF">http://www.uwsp.edu/cps/facilities/classroom/
manuals/VCR/PVD4752.PDF</a>
Feb 23, 2008 | Panasonic PV-D4752 DVD Player / VCR Combo
Open Questions:
Televison & Video Logo
167 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
