Question about GE Cooktops
Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
I have a GE monogram gas cooktop. Model ZG375NSD1SS. It has 5 burners. When I light any of the burners the flame flickers and the ignitor is constantly clicking.
The flames are blue but it seems like they are not getting enough gas to stay lit. There is no difference in the height or intensity of the flame no matter what setting the dials are on.
I've had the plumber check the gas supply line for any blockages and he found none.
Every other gas appliance in the house is working fine except the cooktop.
I've replaced the regulator with a GE regulator that is recommended for this cooktop. The regulator is installed properly.
I checked the manifold line to make certain there are no blockages using a small 1/4" sewer tape. Its clear.
I'm at a loss as to what to check next.
I bought the cooktop as a demo so there is no warranty.
Any insight into what the problem might be would be very much appreciated.
Bret
  • mundt Aug 10, 2008
    textonor,
    I checked the regulator and so did the plumber. It was installed correctly. I am a mechanical contractor and deal with piping and instrumentation every day.
    After doing some research on the specs of an LP cooktop I recognized that the LP cooktops require 10" w.c. of pressure. The regulator provides 4" w.c. of pressure. So I dug into the cooktop and found a label that said....for LP service...
    Problem solved. I ordered the conversion kit and it will be in Tuesday.
    Thanks for taking the time to help me trouble shoot.
    Bret
    Novelist:
  • 130 Answers
Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
Posted on Aug 09, 2008
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
Aug 21, 2012 | General Electric GE Monogram 48""...
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
My GE Monogram 5-burner gas cooktop has a constant buzzing sound. The cooktop is working properly, but the buzzing is annoying.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 23, 2010 | GE Profile JGP636 Gas Cooktop
I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
Jun 15, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
BOILING WATER SPILLED OVER FROM POT INTO COOKTOP AND NOW IGNITOR KEEPS CLICKING
Hi, water is a great conductor of electricity. It is likely nothing to be concerned about in this case though, if you light the burners and allow the water to burn off/evaporate from the ignitors it should be fine. It happens all the time with gas ranges and cooktops. Once the ignitors are dry they will stop conducting/sparking unwanted. Hope that helps calm your concern. Thanks for coming to "fixya" for your solution. Please take a second after reading this to rate the info provided to you. Good luck. Macmarkus :)
May 02, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Gas burners lit, but electronic ignition still clicks
heatman101
fsggfs
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Cooktops Logo
932 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
