Question about Archos 604 Digital Media Player
Archos 604 will not restart
The Archos will no longer work. The system brings up the green Archos logo for a few seconds, then restarts again, but never gets past the green screen. I have held down teh reset button for 10 seconds as recomennded with no effect.
Help!
I had this problem recently when charging on the DVR docking station, i switched it off, took the battery off, left it for a shirt time then pressed the reset, it took a few attempts but eventually it restarted
Posted on Aug 29, 2008
How do u restart iPhone 4
Hold down the lock button and at the same time hold down the home button for about 5 seconds and you will force it to restart
Jun 15, 2016 | Apple iPhone 4S
Code 108 shows on archos 605
The archos 604 is a portable media player. It is not a PC. The Archos 605 WiFi runs embedded Linux on an ARM processor.
Here is a reprint of someone who solved this problem:
i just got my Archos 605 and when accessed the content portal it said i should update my firmware. when i said OK i got the message it faild connecting to the server and my archos froze.
after restarting it i'm getting the Recovery code (108) i tried to repair disk and format disk but both asking me to conncet to the PC and update the system. the problem i cannot conncet to the PC (i don't see the HD) and don't know what to do.
i managed to solve the problem, if you encounter same problem this is what i did:
1. connect the archos to the PC
2. click on repair
3. click on done and wait for a few seconds and you will see the archos as a drive in your windows (be patiant it takes some time)
4. once you see the drive, open it and make sure the System folder is empty, if not delete the file that exists there.
5. put the firmware update file directly on the root drive
6. click repair again on the archos and done.
now it should recognize the update file and perform the update
it worked for me
Oct 19, 2008 | Computers & Internet
Archos 604 wifi.will only play a few seconds of some movies
Hi there, got the same problem too - have tried to put the cinema and podcast add ons to no effect, re ripping dvd didnt help either. if you get any solutions can you email me on sjc5575@yahoo.co.uk its driving me mad!
Oct 08, 2008 | Archos 604 WiFi Digital Media Player
How to deal with this problem
I was watching a film on mine and it paused and I hade to hold in the power button to shut it off.
When I restarted it I get that error message too.
I did the same as everyone else with no luck, so I left it on thinking that maybe running the battery down and charging it again might help but no luck.
I left it for a week then decided to have another go at fixing it.
I removed the battery and used the reset button to set it to factory defaults.
I powered it up and got the error message and tried the USB cable again (Can't remember for sure if it was on or off when I connected it) and I got the option of connecting to my PC and copying a system update to it.
I downloaded the update and copied it to the harddrive and it then updated itself and restarted.
It booted up ok but when I restarted it I get the error message again.
I redid the first bit again and using the XP Disc Management I removed the partition, then redone it.
I restarted the 604 and formatted the harddrive and copied the update and it updated and restarted again.
The pointer needs to be calabrated again on it to work but it's back to normal now and working great.
I set everything up and copied all the folders into a folder on my PC so if it happens again I just need to fix the harddrive and copy the files over.
Jun 01, 2008 | Archos 604 WiFi Digital Media Player
In my screen appears Recovery (code2) System is damaged. Would you like to recover it? and Three options No/ Repair/ Format Disk Even if I choose Repair or Format disk nothing is going on. I checked on...
Also had the Code 2 error. Had a look at the harddisk and noticed the ribboncable in the pcb side was not completely in the socket on one side. Reconnected and started up normal.
Beware, the screws are very small, you need a very small (watchmaker) screwdrive or , as I did as my smallest screwdriver was still too big, a knive. As mentioned before, putting it back together can be fiddly but you should check this first before sending it for repairs.
If you feel uncomfortable to take it part, find someone to do it for you.
Don't loose the screws!
May 16, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 wifi
why dont u try to upgrade the firmware?
Jan 27, 2008 | Archos 604 WiFi Digital Media Player
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
Archos 604 Wifi Recovery Code 2
hello everybody, i had this same problem with my archos 604 wifi but thankx to someone on another forum i fixed it. it is really easy:
first you take the battery off, then you unscrew the 4 or 6 screw on the sides of the hard drive, then you lift the lid and then the hard drive, VERY CAREFULLY, Then you will see the problem : the little black plug conected through a ribbon to the hard drive is not plugged correctly or it is completely unpluged from the white socket. even if it is not un plugged just make sure it's tight, put everything back together and it should work just fine. ( IT IS A LITTLE DIFFICUL TO SCREW IT BACK TOGETHER BUT YOU"LL GET IT RIGHT) it is a weird problem. but it is easily fixed.
i hope that helps, bye
Dec 18, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Archos 604 Digital Media Player Logo
213 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
