Question about Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 pickup roller
Hi
I have problem with replace pickup roller
  • mrnodalo Feb 05, 2009
    do you have a manual how to do this
  • 328 Answers
Need more info. Do you need help in replacing the roller? If so, it is a big job. You have to completely remove the doc feed asm and all covers to get to the roller shaft asm. Best to let a tech do it for you.
Have you tried cleaning it with some roller cleaner. Try a little bit of Goof-Off cleaner on a cotton rag.
Posted on Aug 18, 2008
Fax machine squeals when fax comes through
Usually the squeeking on most faxes/copiers that I come across is from a nylon roller on a steel shaft/bushing. You'll be able to tell by opening the back door and look at the little rollers. The plastic ones are usually the culprit and you'll need to carefully blow air through the holes in the center, or any mounting point/axel. VERY LIGHT oil can be placed on the shafts, but it will take a little while and a few copies/faxes to work its way in there.
Sep 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Our fax will not pickup incoming faxes
The mode is correct. You can check the rings to answer setting. Default is 4 rings. If your phone line is just for the fax try setting rings to 1. Sometimes sending fax machines go into redial before the 4th ring.
Also, sometimes unplugging the power for 10 seconds will clear any memory that may have locked up the machine.
Hope this helps.
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother intellifax 4750 does not answer with FAX signal
Make sure that it is set to fax mode not to phone mode
Jan 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Paper Jam
Hi Art,
Try cleaning the rubber feed rollers with a good grade of isopropyl alcohol.
Make sure the side guides of the feeder are not too tight.
Nov 22, 2008 | Brother IntelliFAX 4100 Laser Fax
Black line on all faxes I send to recipients
open the document feeder and look for wite-out on the small scanner glass.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Rebuilding the brother fuser for the intellifax 4100
Although it fit the broken fuser, it does not mean it's ok.
1-they must have the same number of teeth ( diif. gears have diff. amounts of teeth)
2-it must be the same diameter ( so they can mesh together, otherwise it's touching the tip of hte teeth and may be skipping.
But I'm not sure the double image is coming from there, it would jam the paper because the timing is off.
Anyway you need to eliminate the obvious then see what happens, I think you said you had another tonertry putting that in, if it doesn't work then change the gear for the correct one.
try precisionroller.com
Sep 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Paper jams at pickup from tray
Hi Make sure the paper tray (cassette) is not missing the small separation pad with the spring. It is part of the paper cassette. the roller may be worn so cleaning it might not help. Lawrence
May 06, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
752 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
