Question about Exonic EXD7010 Car Video Player
How to change to color from black and white
The dvd player only plays in black and white and I cant figure out how to change to color.
    Brigadier General:
  • 6,966 Answers
Pls check if your unit has a selection for NTSC/PAL, if yes toggle between the two. It normally would be in the Menu Setting.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 09, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
My dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
Jan 21, 2010 | Cyberhome CH-DVD 300 DVD Player
My dvd player is playing in only black and white. I cannot figure out how to get it to play in color
I have the same problem.My dvd plays in Black And White.I found out A bulb in the tv burned out.The tv will still play color,but any dvd player will play in Black and White.The bulb is $130.00 to 230.00.Hope you have a warrenty like i doo.Thanks Hope ive helped.John from Riverside RI.
Nov 16, 2009 | Panasonic DVD-S35 DVD Player
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Curtis progressive scan DVD player 1071
your not using progresive scan out are u change that back to regual
Feb 06, 2008 | Curtis Progressive Scan DVD Player 1056
TV plays color, dvd black and white
If I understand your post/description, the DVD plays OK except it is in Black & White. If so, change setting from PAL to NTSC or vice versa depending on the region you are in. US operates on NTSC, Most of Europe is PAL.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Jan 19, 2008 | Jwin Electronics JD-VD138 DVD Player
My DVD player, stopped playing in color!
check to see if the coding is set to PAL or NTSC, when watching in PAL, NTSC shows up in black and white. ( NTSC is normal for the USA and a hand full of other countries... PAL is used in ASIA, EUROPE, and most everywhwere else).
Oct 18, 2007 | Panasonic DVD-S29 DVD Player
Tv/dvd combo only plays dvd's in black and white
Finally figured this out. On your remote push tv menu until you get to function. You should automatically be under col.sys. change this to NTSC. Took me awhile to get remote to work here, ended up pushing in the middle of the red vol +,- bar on the right of the remote. Couldn't find the right button according to the directions on the screen. DVD is now in color!! If you are not already on the option to change col.sys, use the red channel up down bar on the left of the remote.
Feb 22, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
Exonic EXD7010 Car Video Player Logo
190 people viewed this question
Top Exonic Car Audio & Video Experts
Tom Chichester
Sudhir maharana
Level 1 Expert
David Liu
Are you an Exonic Car Audio and Video Expert? Answer questions, earn points and help others
