I have a Compaq V2000 laptop that you have to push down on the heatsink to get the pc to start up. Sometimes it will stay on...sometimes it won't. If it does and you move the laptop at all, it will go off. I have removed the cpu and reseated it and then reset the heatsink but still the same problem. How can I get this to work right everytime without having to push down on the heatsink?
    Scholar:
  • 53 Answers
If you press and hold the heatsink area of the notebook, then the notebook turns on and there will be display. This clearly says that this is hardware problem.
Issue must be with the assembling of the notebook. Few parts might not have seated properly(motherboard, RAM etc). The only thing we can try is, disamble all the notebook parts and Assemble back.
You can find the service manual of your V2000 notebook from the below URL, which helps you in assembling process:
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
You said that already you have reseated the processor. That means already you might have tried disamble and assemble process.
If you haven't tried it, then try now. If you have already tried it, then check your notebook warranty with HP from the below URL by entering your notebook serial and product number:
http://h20000.www2.hp.com/bizsupport/TechSupport/WarrantySingleLookup.jsp
Model, Product and serial number will be at the bottom of the Notebook on a white sticker.
If the notebook is under warranty, then you will get free service from HP to repair notebook. If not, you need to contact service center.
Regards,
SIVA
Posted on Aug 09, 2008
    Problem Solver:
  • 4 Answers
Sounds like its defenatly the cpu. Perhaps it has a switch or sumthing to lock it in place when you put it in that you may have overlooked.
I have a compaq V2000 notebook that freezes everytime I start it up. Sometimes I can get past the start up in safe mode, but other times I cannot. I need help fixing the problem
Its virus problem some tools to remove virus but Please, don't run Combofix unless under supervision of someone that knows how to use it. Leave it to the experts. http://combofix.org/
Nov 06, 2010 | HP Compaq Presario V2000 Notebook
My Compaq Presario CQ50-103NR Notebook PC keeps shutting down. Sometimes right away sometimes after a few minutes. The left side of laptop seems to get hot while the right side stays cool. Can You please...
Hi:
You most likely have a heat problem, as you have realized. To fix the problem, your heatsink/fan assembly needs cleaned, and then reinstalled with new heat sink compound. Some disassembly is required, so this isn't an easy job. If you go to a reputable shop, and tell them what you want them to do, rather than just tell them your laptop is shutting down, you should get it done for a fair price!
Apr 23, 2010 | HP Compaq Presario CQ50-103NR Notebook PC
V2000 (2710US) shutting down randomly
try to use other hard disk. if it works on your machine then your OS is corrupted. You might need to reformat your hard disk.
Before reformatting your hard drive safe all the files first because everything will be deleted.
Jul 01, 2009 | HP Compaq Presario V2000 Notebook
Compaq V2710us shuts down randomly with a loud click
Loud click sounds like either a short or overload, causing ground default. recheck inside for any loose connections anything grounding out the motherboard.
Jun 28, 2009 | HP Compaq Presario V2000 Notebook
Power issue Compaq V2000
PLUG MACHINE INTO WALL SOCKET
Apr 19, 2009 | Computers & Internet
Heatsink fan
is the fan running? if not try to replaced new CPU.
May 26, 2008 | HP Compaq Presario V2000 Notebook
HP Presario V2000 Laptop Turning off after a few minutes on
Sounds more like the CPU is over heating. This is a fairly common fault on laptops after dust hair etc build up in the fins of the heatsink from the cpu.
After it blocks up, the fan can not push air through it to cool the cpu down and so the laptop goes into thermal shutdown to protect itself.
May 14, 2008 | HP Compaq Presario V2000 Notebook
Power turns off itself then sometimes won't turn back on for sometime
have you tried your power options, you might have it set up wrong
Apr 29, 2008 | HP Compaq Presario V2000 Notebook
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Random shutting down
Your CPU is heating up it will shut down on you the fan that keeps it cool must of clapped out replace it. Then you should be right..
Sep 12, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
David Payne
David Payne
