Question about Tascam Audio Players & Recorders
What does 'CF detect NG mean?' I have got a tascam DP O2 and whenever I put the memory card in it comes up with 'CF detect NG, please power off,' however the machine works fine without a memory card. I have brought a new memory card and it still does the same thing. The pins are all aligned and everything so I cannot understand what is wrong.
3 Suggested Answers
  • 189 Answers
SOURCE: load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Posted on Jan 12, 2009
SOURCE: Tascam DP-02 error 50:0
this happened to my dr-1 what i did is took out the SD card, used a card reader to put all the songs from the music folder onto my laptop, then erased the songs from the card, reinserted it into the Dr-1 and no more error.
hope it helps. tascam doesn't come with a card reader, they use a usb but i've found that a card reader is faster and easier to manage. you can get one anywhere they sell electronics for about $15. cheers
Posted on Jul 25, 2009
Powers up but wont go past the tascam display screen
While the power is off, take out the CF card then turn the unit on.
Does it complain the card missing?
If so, it is the problem of the card related components.
Look inside the card socket, do you see any pin that is bent out of place?
If so, that's the source of problem.
If you are careful, you can open up the case and use a long nose pliers to straighten it (them) out.
If the socket is OK, try another CF card.
Jan 18, 2014 | Tascam Dp-02cf Digital 8-track Recorder
Tascam DP02CF not responding to anything what should i do nest please?
That's an 8-track recorder that records to a compact flash card. It is not a minidisc recorder.
Oct 01, 2012 | Tascam Dp-02cf Digital 8-track Recorder
Transferring songs onto new CF card
You'll have to create backups of your songs and transfer those backups using USB to your PC. Then with the 8 GB card inserted you can reimport them to the Tascam (USB) and restore them to the current working song which will then get saved on your 8 GB card. Do this for each song and then you can discard (delete) those backed up song files while connected to the PC.
Hope this helps.
bd.
Feb 07, 2009 | Tascam 2488 Portastudio Multitrack...
Load imported songs on tascam dp02 cf
Hope this helps.
bd.
Jan 10, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam DP-02CF: How to transfer files to my computer?
You can't see the fat partition from within the DP-02. It's there, but only your PC will be able to read the contents of the fat partition when you have the USB 'opened' on the DP-02. The manual states that if your CF card is less than 5 Gb in size than you will only see/be able to select one partition. The default CF card that comes with the DP-02CF is only 1 Gb.
If you've created a backup or exported your wav files properly and everything is working ok with the CF, then you should be able to see backup or wav files showing up in the fat partition while connected to the PC. Even if nothing is backed up or exported you should still see the directory structure from your PC with the three folders, BACKUP, WAVE and UTILITY. As you are not even seeing these directories, what may have happened is that the fat partition had become corrupted or these folders had gotten erased.
I would have thought that reformatting the FAT partition would have fixed this problem however and that the DP02-CF would automatically recreate the required directories on the CF media after a reformat. The manual is unclear on this however.
So a couple of things you could try:
1. You describe opening the USB connection as 'push the USB button and then hit enter'. I was assuming you meant that you were selecting 'usb' from the menu and then pressing the 'enter' button to open the usb connection. You may wish to verify that the usb connection is being opened properly first.
2. If the connection is opening ok, and after a reformat you still aren't seeing any folders in the fat partition while connected to your PC with the usb open, you might wish to try to recreating those directories in the FAT partition yourself. While accessing the FAT partition (DP-02CF's removable drive) from the PC create the three directories exactly as named in the manual (WAVE, BACKUP, UTILITY). If that works, disconnect from the PC, try exporting a track or backing up a song again, and reconnect to the PC to see if you can see/access those files now.
Best of luck.
bd.
Jan 02, 2009 | Tascam 2488 Portastudio Multitrack...
Memory poor
This is an error in Tascam's code that usually means 'out of disk space'. Try using 'delete unused' to free up some space first within the song you're on and after that you might consider backing up some songs to your PC and then deleting them from the DP-01 to free up more disk space.
Hope this helps.
bd.
Dec 04, 2008 | Tascam DP01 All-In-One Recording Package...
Pocketstudio 5
A CF card is a compact flash memory card. It's rectangular and has two rows of holes along one side which fit over the connector pins when you slide the card into its socket. Compact flash cards can be bought from electronics or photographic shops, and some department stores. They are not expensive but these days they are usually 1Gb and up. The TASCAM Pocketstudio 5 can only format up to 128Mb so most of a modern card is not used but the card will still work.
Apr 11, 2008 | Tascam Pocketstudio 5 MP3 Player
Mar 16, 2008 | Audio Players & Recorders
Tascam pocketstudio5
Hello tasbones and razzledog !I expect the following will help you solving the problems with the pattern file of pocketstudio5 (TASCAM):You need the original CD-ROM which includes the pattern file with many different drums and sound stuff. You have to put these data on a formatted cf-card (everytime again if you will use a new card) !This info comes from a german musician who had the same problem 5 years ago.Try the following Link of TASCAM where you can download the manual, an update and the PATTERN FILE !www.tascam.de   --> "Support" --> "download" --> "nicht mehr hergestellte Produkte" --> "pocketstudio5"If this will not work, give me a sign - I will try to send the data to you via mail.freewood/Berlin, Germany
Dec 24, 2007 | Tascam Pocketstudio 5 MP3 Player
CF card problem
Perform the following procedures if your camera does not detect a CF card. 1. Restart your camera. - Set the camera's power switch to and remove the batteries. - Open the CF card slot cover to make sure the CF card is securely set in the card slot. - Insert the batteries and turn the power switch . 2. Format a CF card. Format the CF card with your camera. Refer to the Camera User Guide supplied with your camera for instructions on formatting your card. 3. Check if your camera detects other CF cards (If you own multiple CF cards.) If your camera does not detect a CF card after performing the procedures 1 and 2 above, the card that wasn't detected may have a defect.
Aug 29, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
119 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
