Question about Singer 7444 Mechanical Sewing Machine
On my singer 9005 the pressure foot lifter does not stay in the up position - does not hold the pressure foot up.
    New Friend:
When I push the pedal nothing happens. I can hear the machine trying to sew, but nothing happens.
Posted on Jul 04, 2015
  • 27 Answers
These plastic presser bar lifters do wear out a lot ,very common,,,,,,,,You can lift it up and file as close to the machine side on top just a couple of stroke son the file will usually give it a surface to hang on and it will stay up ,much easier than changing the plastic lever
Posted on Jan 10, 2009
How to fix a pressure foot lifter on a singer tradition
You can get a replacement Lifter from Sewing Parts Online here:
Most likely, the screw end on the machine has broken off.
Jan 18, 2016 | Singer 2250 Tradition
Singer 9015
Sounds like the linkage between the lifter and foot is caput. If you open the case, you void the warranty.
May 22, 2014 | Singer Sewing Machines
Singer SM MN 93234--pressure foot lifter won't stay lifted, falls down. What to do?
sorry can't help you there may be you need it check by a sewing machine mechanic may be a screw is lose and need to be tight.
Apr 14, 2014 | Singer 7422
Presser foot lifter
foot pressure needs adjusting
Feb 10, 2014 | Bernina Sewing Machines
The presser foot lifter on my machine is not engaging this allows the needle assembly to spin - is there a way to fix this?
Your question is not clear. The pressure foot lifter only lifts the pressure foot. It doesn't make the needle spin.
Apr 23, 2011 | Singer 5062 Mechanical Sewing Machine
The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Dec 31, 2009 | Singer Sewing Machines
Hello I have a singer model 4552 I cant make the pressure foot stay up...the lever doesnt raise the foot high enough what doi do?
I have a used unit with the same problem. If you remove the plastic housing piece on the far left you can see how the foot lifter works. Raising the lever raises a collar around the main shaft. There is a screw in that collar which connects the collar with the shaft. If that screw is loose the collar will not raise the shaft. Caution: Tighten the screw very carefully, only enough so that the shaft lifts. I just overtightened and the collar has a crack now.
Sep 30, 2009 | Singer Sewing Machines
Singer 7444 Mechanical Sewing Machine Logo
684 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
