Question about Refrigerators
Noisy fan samsung fridge freezer model rs21dgrs
  • 1 more comment
  • Anonymous Mar 25, 2009
    Not only noisy, but it seems to go-on for ever. Clearly is not a good product.
  • paulpaola Apr 15, 2009
    Same problem just started....sounds like a niosy fan in the fridge section....stops when I open the door !!
  • jelcompt Apr 24, 2009
    I have the same problem. Checked behind the panel and no build up of ice around the fan. Replaced the fan motor with one from a previous unit (engineer has ben out to fix once a year so far) and replaced motor does not seem to make same noise so could it sometimes be a specific fault with the motor and not the wider "Watchdog" design fault?
  • 17 Answers
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Posted on Dec 10, 2007
  • 1462 Answers
SOURCE: Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
Posted on May 07, 2007
  • 69 Answers
SOURCE: noisy F&P fridge freezer
Most of f&p make this noise its most annoying, but could also be ice buildup on the fan blades, creaking and cracking is normal as the pipes expand and contract is these thin foamwall fridges, not nice fridges, insulation has been compromised to lower cost, they work twice as hard at keeping cool
Posted on Sep 23, 2007
SOURCE: my samsung fridge freezer da99-00494v
just had same problem
you can
1. turn off and defrost
2. remove all panel of fridge ( inside) fan has got bloked with ice and cannot cool fridge.
Posted on Jun 15, 2008
docjohn174
  • 943 Answers
SOURCE: RS21DGRS SAMSUNG SIDE BY SIDE REFRIDGERATOR
hi thanks for the question it might be a problem with a little frost on the freezer wall fridge not defrosting check the freezer wall with your hand,will feel some frost if this is the problem thanks the appliance doc you
Posted on Sep 17, 2008
Fridge/freezer Samsung3116NW very noisy from left fridge wall Ithink
if the left side of your fridge is the freezer compartment , chances are you have a bad circulation fan . I would suggest replacing the fan motor assembly . The circulation fan is located at the rear of the freezer mounted to the evaporator cover .
Feb 19, 2011 | Samsung Refrigerators
How do you defrost a samsung rs21dgrs
samsung fridge freezer problem
samsung dity help on youtube ">
Dec 29, 2010 | Microwave Ovens
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
Motor freezes up
the issue is not with the motor to be honest you have probably wasted money buy a new fan motor ,
the fan only stops working when ice builds up and forces it to jam , the ice builds up as the defrost heater is more than likely faulty - very common issue on all uk samsung rs21 models ,
to rectify the fault totally its recommended to replace 4-5 components that operate the fridge cooling /defrosting system - sounds complicated but its really just 1-2 hour job for a skilled competent person
have a look at this video , also check the youtube chanel for same guy , there are lots of info on samsung uk american fridge freezers
May 10, 2009 | Samsung Refrigerators
Sep 17, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Refrigerators Logo
1,353 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
