Question about Intel D845GVSR Motherboard
Mic not working with system
The head phone which connect the pc only able to produce output over speaker not willing to record from mic , head phone is working properly when is connected other system
Same problem i am having in my system
Posted on Aug 18, 2008
    Master:
  • 763 Answers
Try to change your system just like the one that youve said that its working. it is maybe the system got the problem. or try this one, go to control panel see if your mic is working on your audio software application. set it to make it work by configuring like the volume or anything. hope that helps!
CHARCOIS
Posted on Aug 09, 2008
Will the Aux. Input port also work as a earphone system to listen to any audio. This system is in a convertible & this option would be nice going down the road...top down.
aux input is exactly that an input system ( mic , other input device etc)
you need a head phone socket for what you want to do ( output socket)
Jul 05, 2015 | Sony Cdx-gt56ui In Dash Car Cd Player W...
Headphones are working and mic is not working
The mics are of two types: electrostatic(cheap and modern) and old-stiled "dynamic". Old souncards were automatically switching to the mics type. Modern soundcards have to be switched manually.
In "sound properties" you first must check in that mic is turned on, mic volume in max and in all menues avd buttons find something like "mic amplifier boost"and turn it on. It's only non-standart mic tuning option in standart systems. All other problems in defects. Soundcards can be verifyed by so:
(with maximal speaker and mic volume) many times plug in and plug out any reacheable mics and headphones to the mic connection nest (hole), and listen(or recording) resulting scratches. If scratches or other related sounds are abscend(only noise), soundcard is bad. The mic problem may be in "jack left-right interconnection". This useful thing may hang some improper cards. Also that cards often cannot work with dynamic type. And they very sensitive to a manufacturer, and model of mic.
Problem may be also in configuring multimode speaker nests in 5_1(7.1) cards like REALTEC - the mic nest may be switched to the speaker output mode. Open Realtec's control center(in control panel or quicklaunch icon) and check in mic nest to "mic mode" or switch mode from 5.1 to stereo speakers.
May 17, 2011 | Computers & Internet
The Mic will record, but when i plug in my headphones into the the mic in the front...it still continues to record when speaking, singing into it...but i cant hear the music (instrumental) in the...
This could be due to the output volume and monitor mix are turned too low. You can fix this by adjusting the input gain levels in the ASIO settings menu.
Apr 07, 2011 | M-Audio Producer USB Microphone with...
I AM W BEGINNER. I MANAGED TO SEE AND CHAT WITH MY SON WAY BUT COULD NOT TALK TO HIM OVER HEAD PHONE. WHY AND WHAT SHOULD I DO?
Your headphone might not have connected properly...
Plugin of speaker and mic should be more carefuly connected if not then cant chat throug mic...
and check internet status while on a chat...
May 30, 2010 | Yahoo Messenger
Dont know how to work the built in mic
Typical audio setup for :-
Laptop x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Nov 30, 2009 | Gear Head WC535I Webcam
Line in / Mic jack help
So we're talking PC here, right?
I don't understand what you want to record. Going from the PC Headphone jack to the PC Line IN might be unwise in order to prevent a feedback loop. External (non-PC) source and PC MIC might work but you would probably want to monitor it on headphones again because of possibe feedback.
Does your MIC work?
Right click the speaker icon again and select Adjust Audio Properties or open Control Panel and select Sounds & Audio Devices. Select the box to place the icon on the Taskbar for future use.
Right click on the little speaker icon in your Taskbar and select Open Volume Control, if it's there. From there you're on your own. I have a sound card so I don't know what you will see. Look around, there may be a bunch of audio outputs and inputs with Master and individual volume & balance controls plus one for your Mic. Make sure it's not muted.
Apr 21, 2009 | Audio Players & Recorders
Sound from my speakers
sounds as if when you connected the recording device may have finnished off the already faulty jack on the PC. Now the PC thinks something is attached but there really isnt. Take it in where it was purchased for repair or replacement.
Nov 12, 2007 | Acer Aspire 5610-4648 Notebook
Sound Input problems
What you have to do is go to your speaker volume icon in the taskbar, right click and go to open volume control and click mute microphone. If mic does not show click Advanced. This dissables the onboard mic but allows the use of your external microphone, rectifying the tinny sound.
Feb 27, 2007 | Acer Ferrari 4000 Notebook
Edirol UA-25
A computer has line out and that means sound out from the computer to your speakers. A line out can also be connected to a recording device or a pair of speakers with an amp built in. Line in on a computer can be used to record audio from other equipment such as a Dj on his decks to record his set. It can also record audio from mp3 players etc. Line in can be used for mic's and also you can use mic in as well. To record any audio onto your computer use line in. Line out can also used for headphones and the mic will plug into mic in so you can talk online.
Oct 27, 2006 | Edirol Roland UA-25 External Sound System
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
